Hole In Metal Roof... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-01-2014, 04:25 AM   #1
Chatsworth's Avatar
Rewards Points: 32
Hole in Metal Roof...
Okay,second posting here (there is so much expertise in here) that I thought I'd inquire about another small problem I'm having...
A few months ago I purchased an old 18 ft truck box that I want to use to store my tools (drill press,grinder,cut-off saw,vise,miter saw,etc),so basically create a man-cave workshop with it.It's got a wooden interior with thick wooden floors and a metal exterior with rounded corners along the roof line.This box was probably manufactured in the '40s or '50s -- it's a well built,heavy box with no wheel wells to get in the way also.
Okay,here's my "big" problem: It's got a low spot on its metal roof with a hole in it,so water pools there during any rain and it naturally leaks.I plan to go to a nearby junkyard and look for a wide headliner bow to run inside the thin ceiling plywood to pop the roof out again so water doesn't pool there,but what of the hole itself?
Those I've talk to want me to coat the entire roof with sealant and other pricy fixes,which is far more than I want to spend (it cost me $400 to ship it here;I added three windows for light and ventilation,etc).I've already spent too much already refurbishing it.The roof is solid except for this hole (bullet?).
Would something simple and inexpensive like a plastic clip utilized in modern cars to hold in rubber and plastic wheel wells work,or a small wide head bolt,wide washer,and a nut work?
I like that last idea,but what would make a good sealant or gasket?
Thoughts or suggestions for an inexpensive fix? I really don't want to put any more money in this old thing.It isn't worth it.
Chatsworth is offline   Reply With Quote
Old 02-01-2014, 06:00 AM   #2
roofermann's Avatar
Rewards Points: 401
Urethane based caulking, slowe's carries the "PL" brand.
roofermann is offline   Reply With Quote
The Following 2 Users Say Thank You to roofermann For This Useful Post:
Chatsworth (02-01-2014), gregzoll (02-03-2014)
Old 02-01-2014, 06:37 AM   #3
Rewards Points: 2,238
Make sure if it's "PL" brand - it's "roofing/siding" caulk -
not some type of construction adhesive!
Or, try "Quad" - "OSI" brand.
(Solar-Seal! - if you can find it!)
rossfingal is offline   Reply With Quote
The Following User Says Thank You to rossfingal For This Useful Post:
Old 02-01-2014, 07:02 AM   #4
Rewards Points: 236
how about a pic from further back ..
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 02-01-2014, 07:18 AM   #5
Rewards Points: 1,294
There are hundreds of rubber grommets installed in the roof of pickup truck cabs every day to cover the drilled hole where radio antennas were and I've never seen one leak even after 20 years. A tubeless valve stem will do the same when pulled through a half inch hole.
The Following 2 Users Say Thank You to SeniorSitizen For This Useful Post:
Old 02-01-2014, 02:47 PM   #6
Chatsworth's Avatar
Rewards Points: 32
Thank you all for the responses.My only question is are any of these products available in "trial sizes",like traveling toothpaste sizes,etc? I would only require a dab.
Fairview: I'm visiting a wrecking yard tomorrow to show a young woman how to strip car parts for her "new" car,so I'll keep my eye out for such things.The hole is not as big as a valve stem (close,though),but that's an excellent idea.It would seal beautifully.
Fix'n it: More pictures coming up as requested.That's why I taped a dime to the original to give some perspective.
It appears these old trailers were built a lot like a building.They framed it first,then they wrapped it in heavy sheet metal.The wood used,is also very hard,heavy,and tough to saw.Did pressure treated wood exist back then? I also had to replace one of its thick 18' floor boards which the guys at Dixieline had never seen.Truly from a different era.
Old 02-01-2014, 02:56 PM   #7
Chatsworth's Avatar
Rewards Points: 32
Added pics...
Here's a couple more pics as requested.The one with the broom is obviously facing toward the front.
I alluded to it's wood in my previous post,and what I don't get is the support piece (the painted one) right near the leak.It bows downward or inward,and no matter how hard I hit it to try to pop it up and therefore pop up the sheet metal skin in that low spot right above it,it springs or pops right back.I wonder if years of leaking water did that to it? Weird,huh? What would be ideal would be to somehow remove it and turn it upside down to utilize it's bow.
Hole in Metal Roof...-roofleak2.jpg   Hole in Metal Roof...-roofleak3.jpg   Hole in Metal Roof...-roofleak4.jpg
Old 02-01-2014, 06:01 PM   #8
In a little over my head
Rewards Points: 706
bolt, nut, 2 fender washers and 2 gaskets made of inner tube rubber. Get an old inner tube free at a bicycle shop.
ratherbefishing is offline   Reply With Quote
The Following 3 Users Say Thank You to ratherbefishing For This Useful Post:
Chatsworth (02-01-2014), oh'mike (02-01-2014), Windows on Wash (02-02-2014)
Old 02-02-2014, 08:20 AM   #9
Rewards Points: 236
Originally Posted by Chatsworth View Post
T
i did not look well enough the first time. no other pics needed.
do this^ . you could also used automotive high temp silicone.
if it were mine, i would weld it. but i weld, so that would be easy for me.
Chatsworth (02-16-2014)
Old 02-02-2014, 08:33 AM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
The patch, short of the welded option, sounds solid as well.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 02-03-2014, 04:44 AM   #11
Apply a coat of acrylic coating to the area around the hole or holes with a paintbrush.Cut a piece of polyester mesh slightly larger than the hole with a pair of scissors. Place the mesh over the wet acrylic coating. Smooth the mesh carefully with your hand to remove any wrinkles.Apply a second coat of acrylic coating over the mesh. Inspect the area to ensure the hole is completely covered. Apply another coat of acrylic coating if the hole is not completely filled.
michelclarke is offline   Reply With Quote
The Following User Says Thank You to michelclarke For This Useful Post:
Old 02-03-2014, 11:38 AM   #12
Low Slope Roofing
Rewards Points: 114
A dab of NP-1... Sorry no trial sizes but at around $6-8 a tube.
1985gt is offline   Reply With Quote
The Following User Says Thank You to 1985gt For This Useful Post:
Old 02-16-2014, 07:45 PM   #13
Chatsworth's Avatar
Rewards Points: 32
Thank you all for your suggestions.Haven't had the time to get out there and work on it,but when I do I'd like to tackle that nagging drooping roof brace right beneath it.Two birds with one stone as they say.
I can only speculate because I'm not familiar with how certain (old) woods react to years of water,or if something else is going on here,but my guess is that the brace was simply subjected to years of water causing it to bow the opposite way.It gets pretty wet in that area after a good rain,so that's all I can go with.It's bowed so much that one can see how it took the nails to the thin plywood right above it with it.
Anyway,one obvious way to remove this "brace"/roof rafter is to remove the vertical bolt holding it in,but that would require I literally remove or lift a great part of the roof's metal skin on both sides to get to it as it is underneath the roof's outer metal skin.Too much work that would require I loosen many exterior bolts to lift the metal skin off it.I also fear it might not go back together as it should.
My thinking right now is to sawzall the brace at an angle (indicated by the red marker lines),drilling a 3/8" hole about half inch deep and looking for a car roof liner rod (or any springy rod) to pop it up.Same idea as it was originally designed but I'm using a metal rod instead. My second thought was to run down to the Home Depot and buy an 8'x2"x2",cutting it slightly larger than the old piece and forcing it into place hopefully with enough tension to provide an upward bow.I'd have to start with a very bowed piece of new 2"x2" to have any luck with my second option.
Is there anything I've overlooked with my ways of addressing it? Any thoughts or suggestions as to what you guys would do? I hope I've provided enough images for you guys to work with.Ask if you need more.
Old 02-16-2014, 07:48 PM   #14
Chatsworth's Avatar
Rewards Points: 32
Here's a side angle to the warped brace,and a shot of it having torn out nails from the plywood right above it.
Hole in Metal Roof...-bowedsupport.jpg   Hole in Metal Roof...-bowedsupportnails.jpg
Old 02-16-2014, 07:54 PM   #15
Chatsworth's Avatar
Rewards Points: 32
Here are both end pieces;one with the red marker where I'd like to cut it.What would be nice would be if I could cut the bolt near the top in between the plywood and the brace(I don't think I could get a sawzall in there),and pulling the bolt out from the bottom out.Hopefully the wood brace would slip out with a little pulling and I could flip it around given me the very bow/arch I need.It would be a beatch forcing it back in I'd bet.
Hole in Metal Roof...-bowedsupportred.jpg   Hole in Metal Roof...-bowedsupportright.jpg
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
Florida metal roof dilemma. DIYorDIEtrying Roofing/Siding 13 11-29-2014 03:18 PM
metal roof conversion ionized Roofing/Siding 5 06-19-2012 08:57 PM
How to repair hole in Standing Seam Metal Roof DaveMorris Roofing/Siding 4 04-18-2009 11:18 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
