Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 04-27-2010, 11:52 AM   #1
Hip Roof Venting
I have a roofing replacementing coming up, and I wanted to know if I should go with ridge vents or box vents? What would be the proper way to put ventalation on this attic? I may down the road finish off the attic as there is a ton of space up there, thought this may be an important factor.
As of now there is vented soffit. However this may need replaced because I have a squirrel problem...
I'm hoping that the pictures show up so it is easier to see.
I'm not the best on roofing, I just know this one needs replaced as it is original to the house (1930) the wood underneath it is boards on a diagonal.
The ridges of the roof have steel caping it off on the outside.
I just want to double check around before having anything done to the roof.
AngKir is offline   Reply With Quote
Old 04-27-2010, 12:06 PM   #2
Hip Roof Venting
I think a powered roof vent would be the best for your roof .JMO
johnk is offline   Reply With Quote
Old 04-27-2010, 10:51 PM   #3
Moderator
Hip Roof Venting
Air seal the attic first: http://www.advancedenergy.org/buildi...%20Studies.pdf
http://www.ronhungarter.com/black_mold.html
http://www.rd.com/how-to-seal-attic-...icle18158.html
Be safe, Gary
Clothes taking longer to dry?
Old 05-02-2010, 08:23 AM   #4
Shut in w/o Home
seeyou's Avatar
Hip Roof Venting
You have little or no ridge to ridge vent. Box vents or larger below ridge vents would be the best option, IMHO. Before installing a powered vent, make sure there is adequate inlet for it (soffit vents) and that the attic is air sealed.
seeyou is offline   Reply With Quote
Old 05-02-2010, 02:29 PM   #5
Commercial Roofing
AaronB's Avatar
Hip Roof Venting
Hip vents are cool, too, if they are PROPERLY installed.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 05-02-2010, 02:44 PM   #6
Shut in w/o Home
seeyou's Avatar
Hip Roof Venting
You have a product you're fond of?. I've never seen one I liked.
Old 05-03-2010, 10:37 PM   #7
Commercial Roofing
AaronB's Avatar
Hip Roof Venting
I think they were made by Mid-America Building Products.
Old 05-04-2010, 07:16 PM   #8
Super Moderator
Hip Roof Venting
I have only installed continuous hip venting on structures that contained a cathedral/vaulted ceiling below, since each individual rafter bay needed an exhaust portal and it worked very well from post job evidence and analysis.
Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon
Ed the Roofer is offline   Reply With Quote
Old 05-04-2010, 07:20 PM   #9
Hip Roof Venting
is there a minimum pitch for the hip vent. i have a situation where i have maybe 3' of ridge
The older I get the better I was
Old 05-04-2010, 07:28 PM   #10
Super Moderator
Hip Roof Venting
As far as the minimum pitch goes, the lowest pitch a proper shingle sloped roof can be is around a 2 1/2 per 12 pitch.
I used the Smart Vent on a mid-roof application as low as that 2 1/2 per 12 which has now been present for 3 winter seasons with not problems.
Ed
Old 05-04-2010, 07:30 PM   #11
Hip Roof Venting
my roof is 4/12. we have roofing suppliers in our area is this a common item? thanks
Old 05-05-2010, 01:18 PM   #12
Super Moderator
Hip Roof Venting
No, it is not common.
Ensure that the brand of Ridge/Hip Vent material manufacturer you decide to use allows specifications for it's installation.
I think that the one that I used was Owens Corning, Vent Sure.
Ed
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Roof Venting Issue, crawlspace supton Roofing 1 11-12-2008 07:44 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof venting question vendejp Roofing 8 07-17-2008 04:45 PM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
