Hip & Ridges W/Architectural Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-24-2008, 09:45 AM   #1
Hip & Ridges w/Architectural Shingles
Hey guys - got a quick question about hips/ridges using architectural shingles. Would someone kindly explain why we use special shingles for the hips/ridges in an architectural-shingle application. And what would be the downside to using the same technique as done w/flat-shingles?
Dav-o is offline   Reply With Quote
Old 03-24-2008, 11:20 AM   #2
The specialty H & R cap shingles usually are made thicker than 3-tabs cut into 1/3. They sometimes have different shadow line accents to look more distinct.
If the color is exactly the same from the architectural shingle being used and a 3-tab color by the same manufacturer, you can use the 3-tabs as the cap instead.
The 3-tabs have the asphalt sealant strip, while the architectural specialty shingles do not. Why??? I don't know. It would make more sense if they did.
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-24-2008, 12:23 PM   #3
Thanks Ed!
Old 03-25-2008, 12:08 PM   #4
Commercial Roofing
AaronB's Avatar
I believe the architectural caps to not have the sealant strip due to increased ridgidity. This would only apply to GAF Timbertex since that is the only arch. ridge cap I have ever used. They are multi-plied.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-25-2008, 01:36 PM   #5
the roofing god's Avatar
Send a message via MSN to the roofing god
I prefer the 3 tab cap with the sealant and extra nailing,I feel it is stronger against the wind,and water intrusion
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 06:53 AM
Falling shingles!! sk8z Roofing/Siding 14 12-11-2007 10:21 PM
shingle over??? lemeno Roofing/Siding 12 12-02-2007 12:39 AM
Does GAF still make 40yr shingles? Marlin Roofing/Siding 8 10-07-2007 01:49 AM
Solar Shingles? CuCullin Roofing/Siding 2 09-21-2007 09:11 AM
