Henry 209 Elastomastic Roof Patch - Good Or Bad? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-26-2012, 06:50 PM   #1
Rewards Points: 302
Henry 209 Elastomastic Roof Patch - Good or Bad?
I have some minor roof leaks around the chimney flashing and vent pipe. I saw this Henry 209 Elastomastic Roof Patch at Home Depot. It was priced a bit higher than the other roofing cements they had and it is making some nice claims on the packaging as though it will handle the job well. Any thoughts or experience with this product?
Eagle One is offline   Reply With Quote
Old 05-26-2012, 06:54 PM   #2
Rewards Points: 13,472
It works fine, but are you sure it's not time for it to be reflashed?
Old 05-27-2012, 12:51 PM   #3
Rewards Points: 302
How would I know if it is time? Just by the age of the original flashing?
Old 05-27-2012, 01:00 PM   #4
Looking at it should tell you.
Is it all rusted out, is there pin holes in it, are there big gaps at the seams, is it still tight to the brick?
Post a picture and I'm sure someone here can see if it was done right.
Old 05-27-2012, 01:07 PM   #5
Rewards Points: 302
Ok, thanks. I will take a close look when I get up on the roof to do the job and post a pic if it is not obvious to me.
Old 05-27-2012, 01:09 PM   #6
Doing This Way Too Long
Rewards Points: 532
I wouldn't waste time or money on anything that says Henry's
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
JWilliams850 (05-27-2012)
Old 05-27-2012, 01:25 PM   #7
Rewards Points: 302
What would you recommend?
Old 05-27-2012, 02:19 PM   #8
kwikfishron's Avatar
Rewards Points: 434
I'd suggest figuring out the source of the leak and correcting the issue.
Goop in a can is a Band-Aid at best. It may buy you some time but it's not a fix.
As mentioned post some pictures if you want to know what you should do fix the problem.
kwikfishron is online now   Reply With Quote
Old 07-05-2012, 03:24 PM   #9
209 Might be the right fit, but 208 and 208R will work as well
Hi EagleOne,
Depending upon yor goals for the repair (Longevity, cost, time, etc.) 209 might be just the trick. Depending upon our area, Henry 208 or 208R may work just as well.
If you are comfortable getting on the roof, and the roof is in otherwise OK condition, you may be able to find the location of the leak - the trickest part. Once you have done that any of the reccommended products should last a good, long while.
Chris
Chris Brink is offline   Reply With Quote
Old 07-06-2012, 07:34 AM   #10
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Roof cement isn't meant to be used on a roof. Find out what's causing the leak, flashing, valley, broken/torn/missing shingle, worn out pipe collar, etc. and replace it.
tinner666 is offline   Reply With Quote
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 06:46 AM
trying to patch flat roof - leak in seam Camera Roofing/Siding 2 11-02-2011 10:25 PM
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
