Help To Waterproof Skylight. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2012, 01:22 PM   #1
Rewards Points: 152
Help to waterproof skylight.
I'm making a shed, I'm gonna put the plywood on the roof soon, but I don't really know how to waterproof the skylight. Do I have to buy some flashing kit, or can I just use some roofing caulking? My skylight is 2 feet by 2 feet.
humberguy is offline   Reply With Quote
Old 05-14-2012, 02:51 PM   #2
Just a DIY guy
the roofing forum may be a better place for this.
M3 Pete is offline   Reply With Quote
Old 05-14-2012, 03:28 PM   #3
cortell's Avatar
Rewards Points: 504
No opening in a roof can just be caulked; flashing is critical. Some skylights come with a flashing kit. The box stores sell these kits, as well.
cortell is offline   Reply With Quote
Old 05-14-2012, 04:25 PM   #4
Framing Contractor
Skylights come with a flashing kit. Where's yours?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 05-14-2012, 04:33 PM   #5
kwikfishron's Avatar
Rewards Points: 596
They don't all come with kits. Especially that craigslist brand.
They all do need flashing though. Post a picture of what you got.
kwikfishron is online now   Reply With Quote
Old 05-14-2012, 06:06 PM   #6
Rewards Points: 152
my skylight didn't come with a flashing kit. Im guessing ill check home depot to see if they have a flashing kit.
Old 05-14-2012, 06:16 PM   #7
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
HD won't have a kit. You'll need a roofer to design the correct kit for your application. Each skylight kit is unique to each skylight.
Do anything less, and it'll be just as good as cutting the hole and just leaving it that way. There are plenty of flashing pix on my website that would give you some idea of what's involved, though I don't recall any SL pictures.
tinner666 is offline   Reply With Quote
Old 05-14-2012, 06:17 PM   #8
Rewards Points: 13,732
Velex sky lights all come with a flashing kiit.
There was to many sky light leaks years ago that now most come with it incuded to avoid DIY flashing.
For a sky light that size your going to have to do some reframing of the rafters.
Old 05-14-2012, 06:37 PM   #9
Rewards Points: 3,628
This is all you need for something that small.
http://www.cofair.com/butyl.aspx
Canarywood1 is online now   Reply With Quote
Old 05-14-2012, 07:36 PM   #10
Metal Roofing
Rewards Points: 600
Is the skylight a deck mount or a curb mount ?
Velux lids do not come with a flashing kit to accomodate all rooof types.
If its a curb mount then your roofer or you need to flash it yourself. This flashing will vari depending on the roof type.
I have 8 skylights being install on a roof atm, all are velux deck mounts. Each flashing kit was $200 extra and are in fact all useless for the roof type we are installing. We are making our own flashings and the customer is returning the kits.
The question is, what kind of roof do you have and what type of skylight do you have.
AndyWRS is offline   Reply With Quote
Greetings from San Clemente Ca: Access Door Install in Skylight Shaft? FINSEEKER Remodeling 1 05-12-2012 05:56 AM
Does skylight need replacing? Ttd0715 Roofing/Siding 17 01-14-2012 03:39 PM
skylight self stick flashing advice Earl0101 Roofing/Siding 2 04-30-2011 09:55 AM
Dome skylight leaking AAK Roofing/Siding 1 10-08-2010 05:47 PM
Cracked Skylight rjordan392 Kitchen & Bath Remodeling 10 05-22-2010 02:30 PM
