HELP! Sunporch Roof Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-24-2009, 12:12 PM   #1
Unhappy
HELP! Sunporch Roof Question....Our porch roof was damaged in a storm, we have corrugated aluminum panels on the roof now. Only a part of the roof was damaged. The roof is on a low pitch. What options do we have for materials to redo the damaged area or replace roof that are inexpensive, durable, waterproof/weather resistant that we can do ourselves? We are up for any suggestions. Thanks.
tfelicia is offline   Reply With Quote
Old 09-24-2009, 12:37 PM   #2
Commercial Roofing
AaronB's Avatar
Pictures would really help to make an accurate assessment.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-24-2009, 12:48 PM   #3
I do not have any pictures that I send at this time. They are home and I have hard copys- not on computer. Can you give me any advice? i was thinking about tin or metal roof, or possibly roll out aluminum (cut to size) overlapping one another and sealing them together with roof cement or something like it.
Old 09-24-2009, 02:38 PM   #4
Commercial Roofing
AaronB's Avatar
What kind of damage was sustained? Corrugated metal panels are pretty inexpensive.
Old 09-24-2009, 02:47 PM   #5
Just the corner of the roof was damaged. The metal is broken/bent...and the inside of the porch from the tree that was on is buckled...and there is a hole in the roof (we tarped over)...but on the inside of the porch is only vinyl ceiling panels. No real stable roof. As I said it was more an awning...than an actual roof that you could walk on. We just want something inexpensive and that we can easily install which will be waterproof.
Old 09-24-2009, 05:35 PM   #6
Commercial Roofing
AaronB's Avatar
If you want waterproof, then you will have to go with a membrane system.
If watershedding will do, then corrugated metal panels could do it.
Tags
sunporch roof question
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Hip Roof Ventilation Question tecboy Roofing/Siding 7 06-17-2008 09:37 AM
question about replacing a shingle roof w tin Moparman Roofing/Siding 4 06-01-2008 12:45 AM
Sagging roof - framing question G.P. Carpentry 7 12-26-2005 04:32 AM
Question about roof wndsrfgrl Roofing/Siding 15 12-09-2005 04:35 PM
