Help With Roof Line On Addition - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-24-2010, 11:35 AM   #1
cen
Help with roof line on addition
I am going to have a contracter add an addition to our home that is 2 storys high. He says he will have a problem with the roof and will have to raise the higher of the two rooflines to make it work. I'm not sure if its code he's trying to follow or if two parallel peaks are a bad idea. I have two photos showing what I'd like to do. I just want to run trusses out from the higher roofline and tie them into the lower roof. It's difficult to explain, hopefully the pictures will help, any advice is appreciated.
cen is offline   Reply With Quote
What to do with roof line Justin08 Building & Construction 18 09-10-2010 12:51 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 01:30 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
