Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 12-20-2010, 11:42 PM   #1
Help repairing failed flashing at a wall/roof/corner intersection
I am residing my garage this week and am attempting to fix a water leak that has allowed water to get behind the siding and run down the sheathing where a corner meets my garage roof. Fortunately the water stayed mostly on the sheathing and did't cause any structural damage to the frame, but it did rot the 5/4 corner boards and various other trim pieces below it and I need some advice on how to properly flash this area.
Attached is a sketch of my exact situation as viewed from the 2nd floor bathroom window.
kooshball is offline   Reply With Quote
Old 12-21-2010, 08:53 AM   #2
Pro Slate Roofer
tinner666's Avatar
The flashing is suppose to pass under/through the corner boards.
Frank
tinner666 is offline   Reply With Quote
Old 12-21-2010, 05:55 PM   #3
Pro Slate Roofer
tinner666's Avatar
Not sure what that diagram portrays.
Maybe this will help you. This dead end valley has 2-3 corner scenarios that may apply.
http://www.albertsroofing.com/Valley%20Details.htm
Frank
Old 12-21-2010, 09:41 PM   #4
Doing This Way Too Long
More than likely no diverter on that wall when they installed the step flashing and wrapped that corner.
OldNBroken is offline   Reply With Quote
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 06:51 PM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 01:50 PM
flashing help needed endgrainguy Roofing/Siding 3 12-31-2009 11:09 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
