Help Need Assistance With Bad Roof Design - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-11-2006, 07:04 PM   #1
help need assistance with bad roof design
I have a leak that I can't figure out how to repair. Second story roof intersects with with the garage roof about 3 feet from the peak causing a 3' x 8' long horizontal valley. that valley drains onto the garage roof. the upper roofs soffet is 2' and also rests on the garage roof. the leak is coming from where the valley drain onto the garage roof and where the soffet rests on the roof. How do you recommend I tye the two roofs together. thanks
adam is offline   Reply With Quote
Old 07-11-2006, 09:20 PM   #2
MJW
A picture would be easier.
From what I gather, you have to flash the fascia that is under your valley. Common mistake, but that is just my guess. Not quite sure what you are describing.
MJW is offline   Reply With Quote
Old 07-12-2006, 11:24 AM   #3
I will try and get a picture of the roof posted. Its just a dumb design, gabel roof intersecting with a gabel roof short of the lower gabel roofs peak. creates a bad flat valley that has always been a problem.
I think you maybe correct, I don't think there is any flashing behind the facia.
Old 07-12-2006, 07:16 PM   #4
a picture would help.
May need to install ice/water shield in the area that is leaking?..?
redline is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
