Help Me Interpret This Code. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-18-2007, 11:19 AM   #1
Rewards Points: 398
Help me interpret this code.
Drip edge at eaves shall be permitted to be installed either over or under the underlayment. If installed over the underlayment, there shall be a minimum 2 inch width of roof cement installed over the drip edge flange.
I looked at some new construction rough-ins and noticed they install the drip edge at the eaves over the felt. I came back later and no tar was applied. Maybe, this is because I live in a warm climate where no ice forms. If I install it over the drip edge, I do not need to seal the shingle to the felt with tar. What is a better method? Should I do over the felt for the rakes and under for the eaves. No ice and water will be installed because of the warm climate.
Malcolm is offline   Reply With Quote
Old 06-18-2007, 12:22 PM   #2
PHP Code:
Yes, do it this way.
The roof cement verbage is old code language and refers mostly to ice damming prevention of leaks. It makes more sense to go under the felt along the eaves though, regardless.
Ed
Ed the Roofer is offline   Reply With Quote
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 02:57 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
code question JustJoe Building & Construction 3 01-27-2007 09:06 AM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
