Help It Looks Like Poor Attic Ventilation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-16-2014, 08:25 PM   #16
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
Attic ventilation is best if it is balanced and passive.
Old 02-20-2014, 02:53 PM   #17
I just noticed some dark brown spots on the soffit and siding where water drip only on the same side where roof vents are. Again it tells me moisture builds up on the same side drips down the roof sheathing trough soffit and on the side of the siding. Any thoughts? Anyone?
Atticissue is offline   Reply With Quote
Old 02-25-2014, 04:45 PM   #18
Ridge Vent
Personally, I would put a ridge vent across the entire ridge of the roof. Don't go with just some of the ridge. It has to be flashed correctly, so if you don't trust yourself in doing it, get someone who knows how to help, or hire a professional. Especially where you live, it seems that would be standard instead of vents here and there.
TedLeger is offline   Reply With Quote
Poor Ventilation Causing Ice Dam? Splash Roofing/Siding 1 02-28-2013 01:37 PM
Ventilation - Opposing gable, limited soffit + box vents = Screwed up? darlingm Roofing/Siding 1 09-07-2011 10:13 AM
Honeywell Visionpro IAQ function 406 ventilation in high humidity ? Charlie123 HVAC 1 05-08-2010 11:19 AM
Proper Balanced Ventilation? echase Roofing/Siding 8 04-21-2010 04:44 PM
Light, Ventilation, and Heating code requirements sarbear HVAC 12 11-30-2009 11:10 AM
