-   -   Help identifying soffit/ceiling material (http://www.diychatroom.com/f9/help-identifying-soffit-ceiling-material-200298/)
greg98 05-04-2014 02:26 PM
4 Attachment(s)
I bought a house that was built in 1951 in the Los Angeles area. It has obvious roofing issues, but I want to know if someone can tell me what the ceiling and external soffits are made from (they're the same material - house has no attic, just exposed beams and ceiling, and basically just continues outside).
It's a soft material - almost like a cross between cardboard and fiberboard. I'm thinking it might be beaverboard?? It is obviously rotting outside, just want to make sure I'm not dealing with some kind of hazardous material (asbestos?)
Photos below are the ceiling just over the front door, and then two of the exterior soffits.
UPDATE: Fourth picture is a piece I pulled down - the consistency is almost like multiple layers of compressed cardboard(??), and/or soft fiber board. It's very soft and "flaky".
de-nagorg 05-04-2014 02:45 PM
Might be a fiber-board material, but that is not recommended for a wet environment. Since it has to come down anyway, take a piece of it to your county health department, or the building inspectors office, ask them their advice on it, Or get an asbestos lab to evaluate it for you.
ED
greg98 05-04-2014 02:52 PM
Thanks Ed. I pulled piece down and took a photo, not sure of that helps. Obviously the soffits have to go, but I'd rather not have to pull out the entire ceiling if there is any way around it.
de-nagorg 05-04-2014 04:18 PM
Without actual hands on this stuff, I am not sure what it is, It resembles stuff that was made back then that was tar infused on one side, and semi permeable on the other for roof sheathing, and wall sheeting, but after 65 years in the weather it has obviously deteriorated. I would have it analyzed and see if it is asbestos infused also, and if not then try to just remove the rotted parts, and go with modern materials.
ED
AndyWRS 05-04-2014 06:48 PM
I see that in Orange and Garden Grove usually. I think the last time I did a reroof on one we got it at either Christian Building Materials in Orange or ABC Supply. Same issue you have, the eves had water damage.
If you cant find it just layer plywood in to match the existing roof deck, I think its about 2" thick and has a T&G edge.
greg98 05-04-2014 07:40 PM
After poking around and researching some more I'm pretty sure this is something along the lines of Celotex or Homasote - one of the older fiber board materials they used to use. Really should be used for exterior (for obvious reasons), but any way.
I think next weekend I'll cover up really good, wear a good mask and tear it out, trying not to make too much dust. Once I have the roof done I'll upgrade to a more "modern" soffit material.
Thanks for the answers, much appreciated!
de-nagorg 05-04-2014 09:16 PM
Celotex. That's the name I was struggling to recall.
Thanks for the reminder.
Sounds like you got a plan now.
ED
greg98 05-05-2014 10:17 AM
Solved
OK, so I think this mystery has been solved. I reached out to the Homasote company and they answered me, literally within a few hours.
This appears to be Homasote "Easy-Ply" roof decking. One of the most common/popular applications for this was homes with open beam ceilings, and the good news is that it is 98% recycled paper, and contains no asbestos or carcinogens.
Thanks to everyone for their help.
de-nagorg 05-05-2014 12:12 PM
That is good news, now you can D I Y to your hearts content. :thumbup:
just remember safety first, that fall wont hurt you, it's that sudden stop at the end that really hurts.
ED
