Help With Gutter Hanger - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-28-2008, 02:17 PM   #1
I am putting up gutters but my facia board is angled so gutter will slope inward with a normal hanger. could anyone please let me know what my options are and where I might find these type of hangers. I live in the Mpls MN area
RKO52083 is offline   Reply With Quote
Old 06-28-2008, 02:59 PM   #2
They sell gutter wedges which are made in various angles, depending on how far the fascia board is slanted back.
The fastener for each gutter hanger also penetrates through the pilot hole of the top of the wedge and allows the gutter to wind up plumb.
I am sure I posted links on this forum before, so I will do a search.
http://guttersupply.com/p-wedges.gst...utter+wedge%5D
and
http://www.gutterworks.com/endcaps.html
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-28-2008, 03:14 PM   #3
Wedges
Thanks Ed. If i understand then these wedges would go behind the gutters, against the facia board and the gutters would rest on the wedge every 24 inchs. I would think that they would show some from the bottom, but they only come in White?
Old 06-28-2008, 03:23 PM   #4
I have used Brown and Black also.
Did those sites only carry them in white?
Yes, they should be spaced "No Farther" than 24" on center. You should try to anchor all of the gutter hanger fasteners into the tail end of the rafter, so if your rafters are 16" O.C., then you should set them at 16" apart.
Ed
Old 06-28-2008, 04:26 PM   #5
Wedges
The first site only had white. the other sites wedges had brown and you cut them depending on the angle. The 16inchs apart is a good idea thanks. That is as long as I can find rafters. I suppose just measure from the edge of house then 16 inchs on center. thanks for your help.
Old 06-28-2008, 07:06 PM   #6
If the fascia is not already clad with aluminum, you can find the rafter tails by looking for the nail heads that secured the fascia board to them. Even if they are painted and seem sealed, you will still notice them if you look with a keen eye and then just fo and mark them with a carpenters pencil.
Ed
Old 06-29-2008, 12:40 AM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
on slight pitches,we`ve used beveled pine siding to accomplish this also
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 06-29-2008, 12:42 AM   #8
It`s important that you don`t pitch the gutter too far back,and create another problem with backup
Gutter Heaters kennykenny Roofing/Siding 17 02-29-2012 03:43 PM
replace eavestroughs? gutter protection? kianeedshelp Roofing/Siding 4 07-05-2008 10:02 PM
Proper way to install gutter flashing? Kasfidan Roofing/Siding 3 03-17-2008 01:57 AM
Gutter problem erikb622 General DIY Discussions 1 02-05-2008 11:54 AM
facia repair and gutter boman47k Carpentry 2 09-11-2006 08:06 AM
