Help With Fixing A Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-20-2013, 10:58 AM   #1
Question
Help with fixing a roof
Hi there,
This is my first post (of many, I hope) on this forum.
Just a year ago, I had a house built on the tropical island of Bali. The house was just about finished in the middle of the dry season and everything looked fantastic. The mood quickly changed once the raining season started in all its glory and leaks appeared at a terrifying rate. The raining season is almost finished now, and I will have about 5 months of perfect dry conditions to fix it properly.
My roof pitch of 7/12 (about 30) is the minimum recommended in this country, so no real problem with that. My ceramic roof tiles, however, are made locally (hand-pressed), and are not heated enough to create strong tiles; hence they are brittle and not all the same size (size variation of about 1 to 2 cm). Moreover, I have noticed that the builder did not respect the minimum 7.5 cm (3 inches) overlap. The tile overlap on my roof varies from 4 (1.6 inches) to 7 cm (2.75 inches), which might pretty much explain the leaks. Current tiles are 30 cm (11.8 inches) long, and current batten distance is 23 cm (9 inches).
I am planning to buy some stronger and longer tiles of about 33 cm (13 inches), and I am planning to install them without changing the current batten distance (9 inches) to increase the overlap of each tile, and in turn stop the leaks. Does it make sense to do that? Do you think it will help? The only downside of doing this, I think, is that I will have more tiles per m2, which will be more costly.
Thanks for your help.
Daniel
danielstassen is offline   Reply With Quote
Old 04-20-2013, 10:01 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
The more lap the merrier. With tile and slate, minimum, and only on steep roofs is 3". 4" or so should do you fine.
tinner666 is offline   Reply With Quote
Old 04-20-2013, 10:13 PM   #3
That's what I thought! Thanks for confirming this
All my tiles are way below the minimum lap of 3''. The builder probably ripped me off as he used less tiles and could finish the roof faster...
Repair + roof coating options Fishbone90 Roofing/Siding 23 11-12-2012 10:44 PM
Simplest options for fixing the shed roof tx42 Carpentry 5 10-01-2012 12:41 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Fixing a leaking concrete roof akankoh Roofing/Siding 7 04-28-2010 11:16 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
