HELP - Finishing Row On A Shed Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-25-2008, 05:24 AM   #1
Unhappy
HELP - Finishing Row on a Shed Roof
I need some advice...
I've got a firewood shelter I'm building with a shed roof on it (simple shed roof - no peak - just a slanted flat roof - see the attached image).
I'm putting felt and composite shingles on it - but am puzzled on how to finish it - when I get to the last course - at the top so it looks decent (it will be right at eye level)...
What is the proscribed manner of finishing such a roof? To use dripedge over the top - or cut some tabs off or something? How do I keep the edge from otherwise being exposed?
Thanks for the assist!
Makes More Work is offline   Reply With Quote
Old 06-25-2008, 06:33 AM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
An 'over-bent' piece of metal shaped like an 'L'. When bent right, it will conform to slope of roof and point straight down.
tinner666 is offline   Reply With Quote
Old 06-25-2008, 10:37 AM   #3
What Tinner said...
johnk is offline   Reply With Quote
Old 06-25-2008, 12:42 PM   #4
So just a piece of L flashing or drip edge then - just nailed in place (w/ roofing nails)? I figured it would be something like that - I was just hoping that there would be a solution a bit more elegant than that (since it's at eye level)....
Old 06-25-2008, 04:59 PM   #5
I would use screw with rubber grommets to fasten it
Old 06-25-2008, 06:27 PM   #6
Pro Slate Roofer
tinner666's Avatar
You can get creative and nail strips of matching metal where the flashing is going, and bend it up and over the trim to attach it. Allow 8" either way and see what 'design' suits your needs best.
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
