Help In Deciding The Underlayment For Roofing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-25-2012, 09:28 PM   #1
Help in deciding the underlayment for roofing
Our roofer offers Rhino Wrap Synthetic Underlayment as a standard. If we want "Certainteed Diamond" underlayment (we'll have Certainteed Landmark Pro shingles), it is considered upgrade. Is it worth the extra cost to upgrade to "Certainteed Diamond" underlayment? Need a decide asap. Appreciate a quick reply. Thank you!
homeroofing2 is offline   Reply With Quote
Old 12-25-2012, 09:31 PM   #2
Rewards Points: 13,296
#1 Go back and add your location to your profile.
Not worth the extra money, underlaymant is not what keeps a roof from leaking.
Only time it would do anything is if the shingle blew off.
homeroofing2 (12-25-2012)
Old 12-25-2012, 09:55 PM   #3
Thank you. Sorry I did not figure out how to add location to my profile. I am from PA.
Also do we need new pipe covers for the existing vent pipes when we have the new roof installed?
Old 12-25-2012, 10:01 PM   #4
Alway change the flashings.
Make sure to have drip cap installed.
Got a picture of the roof?
Old 12-25-2012, 10:03 PM   #5
Look toward the top right, see where it says your name? Give it a tap and add it there.
Old 12-26-2012, 12:00 AM   #6
ParagonEx's Avatar
Rewards Points: 150
I use Rhino synthetic no matter the shingle being installed.
Just ask him to install the rhino with the landmark pros. It isn't a problem.
ParagonEx is offline   Reply With Quote
The Following User Says Thank You to ParagonEx For This Useful Post:
Windows on Wash (12-26-2012)
Old 12-26-2012, 12:10 AM   #7
Thank you!
also the contract has
1) for shingles, it will be installed with four 1 1/4" galvanized roofing nails.
2) for flashing, copper flashing will be installed at chimney. Aluminum flashing will be installed at all other abutting areas.
Is this detailed enough? Thank you!
Old 12-26-2012, 02:19 PM   #8
Rewards Points: 330
re; I use Rhino synthetic no matter the shingle being installed.
Are synthetic "felts" walkable at 6/12 pitch? how does a morning dew
affect walk ability?
kt82 is offline   Reply With Quote
Old 12-26-2012, 04:28 PM   #9
ParagonEx's Avatar
Rewards Points: 150
Yes. I can personally walk on synthetic underlayments up to a 9/12.
I'm not sure about morning few because we roof what we tear off the same day except for extreme cases.
kt82 (12-26-2012)
Old 12-26-2012, 05:01 PM   #10
I wouldn't worry too much about the brand of synthetic underlayment.
When I did my roof this summer I tried to research synthetic underlayments, and I couldn't find anything that says there is any significant advantage to synthetics versus felt, or any particular brand of synthetic versus another once the roof is complete. There are advantages for the installation itself, but once the roof is done, it's the quality of the shingles and installation that will make the difference on your roof.
Unfortunately with these types of new building materials, it takes several decades before you know how well they worked. So come back and ask somewhere around 2030 or 2040 and you will get more informed answers.
wrongdave is offline   Reply With Quote
Old 12-26-2012, 05:05 PM   #11
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,900
Polyethylene is not a "new" building material. In this application, it less than 30 years old, but hardly unknown commodity.
It is vapor impermeable, more so than felt, which is a benefit. Enough to make me choose a roofer over another that uses felt...no.
Old 12-26-2012, 06:52 PM   #12
Rewards Points: 330
[QUOTE=wrongdave;1080044]I wouldn't worry too much about the brand of synthetic underlayment.
15# felt in the Texas market is not even 15 lbs anymore.
it is more like kraft paper with no oil in it
it rips,crinkles in the morning when cold, and trying to walk on it
when the temp hits 100 is futile
why when I was younger and Certainteed used virgin paper
and real tar ,never mind
.it's 19 F out there and I refuse to leave the house
Old 12-26-2012, 06:54 PM   #13
Rewards Points: 330
I thought the shingle manufactures required the underlayment to be "vapor permeable" or the warranty was voided?
Old 12-26-2012, 06:56 PM   #14
Negative.
Shingles don't need to dry out through to the plywood.
Old 12-26-2012, 07:18 PM   #15
Rewards Points: 330
I was wondering where the water vapor between the underlayment and the OSB goes
#15 has a metric perm rating of 37.7
#30 22.2
while a typical "peel and seal" membrane is rated at .05
which implies to me that no vapor will pass thru the membrane which is good right?
I guess I should get back and finish my taxes.
Tags
roofing materials
1/2" sublfoor...what underlayment for hardwood? Jrhenry24 Flooring 10 10-04-2012 08:57 PM
concrete tile roof underlayment recommendations?? bobinphx Roofing/Siding 9 08-14-2012 11:20 PM
Replacing underlayment in entire house...what material to use? Dave321 Flooring 23 12-23-2011 03:38 PM
Underlayment question-- "extending" existing underlayment fastener and type cbrc5eric Flooring 9 06-01-2011 05:03 PM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 01:12 AM
