Heat Tape On Edge Of Flat Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-13-2010, 10:39 AM   #1
heat tape on edge of flat roof?
Can heat tape be used on a flat roof that has eave troughs but no overhang?
Syles is offline   Reply With Quote
Old 10-13-2010, 11:31 AM   #2
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Sure, but if you use any fasteners you're going to have a heaping helping of water coming through the roof.
Keep in mind that heat tape is a band aid approach to solving a problem. That problem presumeably is ice damning. Ice damning occurs primarily from snow melt upon the bottom side of the roof deck. This is a result of improper ventilation and or insulation. You may read more about it here Ice damming and Attic Ventilation, while this article is intended for owners of sloped roofs the principals are the same with flat roofs.
Further more ice damning is formed when drainage becomes blocked, such as gutters and down spouts. This is especially true with typical Chicago residential flat roofs because the often only have one downspout which quickly freezes. The cure (in addition to ventilation and insulation) is usually larger gutters and/or down spout and the addition of a back up downspout.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 03:45 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
Commercial heat tape. rforsha Electrical 3 12-04-2007 07:41 PM
Flat Roof Suggestion gladiator Roofing/Siding 3 09-14-2005 03:31 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
