Heat Tape - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 10:06 PM   #1
heat tape
I need to run heat tape between an exterior wall and a roof.
Can heat tape be run through copper or any other pipe that could than be attached to the roof?
iversonb is offline   Reply With Quote
Old 08-25-2009, 11:10 PM   #2
We had to run a commercial grade of Heat Tape through a drain pipe from an In Wall Roof Drain on a TGIF Restaurant, because the coldness and lack of sun striking that wall would freeze up the pipe and back up the water on the entire roof surface, which was a hot asphalt built up roof system.
So, that was either cast iron or pvc pipe as I don't remember from over 15 years ago the exact details.
Ed
Ed the Roofer is offline   Reply With Quote
Old 09-02-2009, 08:38 AM   #3
Rick's Renos
Heat tapes are often run through water lines to keep them from freezing also drain lines. Check with a local plumber or a local plumbing supply outlet. They should be able to give you details of this type of installation.
Rick's Renos is offline   Reply With Quote
Need advice on roof heat tape. marchboom Electrical 52 12-04-2011 03:45 PM
Heat tape WITH insulation justinae Plumbing 2 03-25-2009 10:50 AM
Heat Tape on Pipes and Pressure Pump msully8548 Electrical 4 08-27-2008 11:33 PM
Commercial heat tape. rforsha Electrical 3 12-04-2007 07:41 PM
