Having Problems With Roofing Nails - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-22-2012, 09:13 PM   #1
Rewards Points: 152
Having problems with roofing nails
I am trying to copy this shed, im currently putting shingles in the roof and ran into a problem. The shed has an overhang that's exposed white. I have problems trying to put the nails through the shingle without the nail being exposed on the white overhang.
I bought some adhesive to glue the parts of the shingles that are on the overhang, but i dont think it will work. My waferboard on the roof is 7/16 inch thick, i cant find 1/2 inch roofing nails in homedepot.
The only option i have is that i nail down the shingles and cut off the exposed part of the nail with a grinder.
Are their 1/2 inch roofing nails available? Is their a simpler solution to this problem?
humberguy is offline   Reply With Quote
Old 05-22-2012, 09:26 PM   #2
ParagonEx's Avatar
Rewards Points: 150
Nails should protrude at least 1/4 of an inch through the decking.
You can create your own fascia board and install a soffit of you're really concerned about the look.
ParagonEx is offline   Reply With Quote
Old 05-22-2012, 09:29 PM   #3
Rewards Points: 6,652
I would do the soffit also, since most sheds get unbearably hot during the Summer. Hopefully you put in either a ridge vent, or some kind of venting on the roof, before doing the shingles.
Old 05-23-2012, 12:34 AM   #4
Doing This Way Too Long
Rewards Points: 532
They make 5/8" roofing nails. We don't call them finger bangers for nothing.
Yes, other option is to get some horse nippers or a grinder and cut them all when done.
OldNBroken is offline   Reply With Quote
Old 05-23-2012, 08:21 AM   #5
Rewards Points: 12,818
That shed would look so much better with some simple look outs to not have that OSB showing,
Old 05-23-2012, 10:25 AM   #6
Rewards Points: 532
Am sure he doesn't want to make major changes at this point.
Nice looking shed. I like the way you used the siding on the door panels.
Old 05-23-2012, 03:02 PM   #7
RFN-4A-LVN
Roofmaster417's Avatar
You can use the shorter fasteners and still maintain 100% manufacture coverage on materials.Just use them only in the areas that will affect the visual aesthetics.Overhangs etc.
A 5/8"-7/8" nail will only cause a slight protrusion in the overhang.The only way it catches your attention is if you are looking for it.
Use moisture guard and 30lb felt to build it up.By the time you put a nail into the shingle,starter,30lb,moisture guard then the fastener will seat perfectly.
Roofmaster417 is offline   Reply With Quote
The Following 2 Users Say Thank You to Roofmaster417 For This Useful Post:
OldNBroken (05-23-2012), Windows on Wash (05-23-2012)
Old 06-15-2012, 10:13 AM   #8
Rewards Points: 850
5/8ths is whats used on new roof on overhangs. if you in a really windy area you want the nails to go though for holding. you can always box the eves in to cover up the nails that come though.
hotrod351 is offline   Reply With Quote
Old 04-08-2014, 04:07 PM   #9
Soffit is definitely the way to go. It will give you that needed circulation in the summer and something to bite into with the nail.
lawrence.crush is offline   Reply With Quote
The Following User Says Thank You to lawrence.crush For This Useful Post:
joecaption (04-08-2014)
Old 04-08-2014, 10:44 PM   #10
Rewards Points: 142
nice look'n shed. i don't want to jack this thread, but let me ask. what size is it ?
Fix'n it is online now   Reply With Quote
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
Rusty nails FatAugie Roofing/Siding 6 08-28-2007 10:25 AM
Coiled roofing nails for nail gun twaters12 Roofing/Siding 3 02-06-2006 08:37 PM
