Has Anyone Used Xtreme Trim Snapvent In Their Soffits? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-30-2015, 09:29 AM   #1
Rewards Points: 16
Has anyone used Xtreme trim snapvent in their soffits?
Anyone used these before?
http://www.xtremetrim.com/products-ventilation.php?i=5
Price is comparable to what I can get at home improvement stores.
We're replacing our soffits and I'd like to do a nice looking continuous soffit vent. Existing soffit material is plywood and we're going to be replacing it all.
Thanks!
kap543 is offline   Reply With Quote
Old 04-30-2015, 11:28 AM   #2
Rewards Points: 13,750
Are you going to remove all the plywood and go with all vinyl and wrap the fashia with coil stock so there's no more painting?
If so that the wrong vent for doing that.
http://www.certainteed.com/products/vinyl-siding/soffit
Old 04-30-2015, 11:50 AM   #3
Rewards Points: 16
No, we are just going to be replacing the old plywood with new plywood. We would have to replace the wood anyway to install vinyl over it. I don't think that vinyl would look good with our type of house. There is also a rock wall facade that the soffit has to fit snugly with so whatever we use can't have ridges.
Old 04-30-2015, 05:55 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
There are nicer vinyl soffits out there.
Don't look at the cheap stuff at the big box stores and think that is the standard.
Old 04-30-2015, 07:13 PM   #5
Registered User
Rewards Points: 5,520
In their brochure, the soffit vent should be installed nearest the fascia for optimum airflow. Farther away from the house keeps rain/snow out better. Also limits sun warmed siding heat flux from wind flowing up the wall to further warm your attic in the summer. The circular holes tend to clog with moisture/dirt faster than the strip vents which are long slots, not holes. Any circular hole will clog, eventually. Use a double-louvered one, it will catch optimum winds.
Be sure to use a ridge vent with baffles to reduce snow in the attic, if location warrants it. The baffle also helps exhaust the attic with wind blowing over it. (Venturi action "sucks" air out).
Gary
Question about hardiepanel/T-111 and window trim Alan Roofing/Siding 4 08-22-2014 09:06 PM
How To Seal Tyvek Terminations At Wood And Composite Trim? gunner666 Roofing/Siding 5 08-06-2014 01:52 AM
Replacing Small Sections of Rotted Trim FrazzledMom Carpentry 2 07-07-2014 06:15 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 12:16 PM
