Hardibacker On A Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2009, 07:10 AM   #1
hardibacker on a roof
A friend is suggesting i use hardibacker board as an underlayment for a rubber roof that gets some foot traffic. Any opinons on that?
grussoli is offline   Reply With Quote
Old 08-25-2009, 07:16 AM   #2
Hardi backer does not provide any support for walking/standing
Old 08-25-2009, 07:18 AM   #3
Residential Roofer
Slyfox's Avatar
I never done it that way, but see no reason why you could not.
There are walk pads made by manufacturers for that type of situation that you install over the roof after it's been completed.
You can find materials for both methods on line at places like ABC Supply and see which method is best for you.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 04-26-2012, 01:10 PM   #4
Hardibacker is meant to be used over a solid underlayment like 3/4" plywood. I wouldn't use it by itself if it's going to be walked on even occasionally.
Tomboy123 is offline   Reply With Quote
Old 04-26-2012, 01:26 PM   #5
Rewards Points: 13,712
And what would you gain by doing it? It's not water proof, will just crack if not properly supported, will just add more weight to the roof, more places for water to leak in.
Old 04-26-2012, 01:52 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
Do you mean as an underlayment or as a topper?
Old 04-26-2012, 01:54 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You are trying to respond to a post from 2009, and submitting a question to a new member (first & only post) that has not been back since that time.
- Build Well -
Old 04-26-2012, 03:27 PM   #8
I did not look at the thread origination date.
I just saw the bump by Tomboy123
Good catch....
Old 04-26-2012, 10:01 PM   #9
RFN-4A-LVN
Roofmaster417's Avatar
You are trying to respond to a post from 2009, and submitting a question to new member (first & only post) that has not been back since that time.
I often wonder if that is a forum joke by people lurking waiting for an unsuspecting member to bite on. .,
Digging up the dead threads.,hahahaha.,Believe me I have done my fair share of responding to the threads of the dearly departed.
Roofmaster417 is offline   Reply With Quote
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
