Hardi Vs Smart Side - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-12-2013, 04:29 PM   #1
Rubbin walls since'79
Brushjockey's Avatar
Hardi vs Smart Side
Getting a new garage built ( in Mn) and need to make some decisions.
Is Smart Side better than Hardi board?
My gut feeling is a cement board would be more long term durable than an engineered fiber board- looking for some experience on this-
thanks
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 08-12-2013, 04:38 PM   #2
kwikfishron's Avatar
Rewards Points: 180
Well Brush I spent a good part of the 80's installing LP Siding and half of the 90's hauling it to the dump after the Class action settled.
LP re-branded their product and now call it "Smart Side". I'm sure they made some changes but it looks the same to me. Just my 2 cents.
kwikfishron is online now   Reply With Quote
Old 08-12-2013, 04:57 PM   #3
Thanks Kwik- Asked the contractor same thing- his reply..
The Smartside is a much better product and completely water resisitant. It's not fiber board - it's OSB - oriented strand board - it' resin treated to never take on moisture - I can get you a sample and you can soak it in a pail for a week if you'd like - Cement siding never get's treated or painted on the back side and it still get's wet there - condensation and wind blown rain.
thoughts?
Old 08-12-2013, 05:28 PM   #4
Rewards Points: 180
thoughts?
Hardie hit the market about the same time as LP was failing and was marketed as the new builders panel. I was skeptical and put a ragged edge piece of Hardie in a bucket of water and 6 months later it was looked the same as the day I put it in.
I'm not sure what LP did to improve their product but at the end of the day it's still OSB so I guess it comes down to how much faith you have in the resins. I guess I kind of have a bias attitude toward LP because for years before any settlements my customers were calling me with their LP siding problems since I was the one that sold them on it to begin with. Burn me once..........
I'm not a big fan of Hardie Plank either (just aesthetics issues) but between the two it would be fiber cement for me.
Old 08-12-2013, 05:45 PM   #5
Just watched a bunch of vids and it does seem that the Smart Side is not the same as the old LP products.
Check this out..'
Old 08-12-2013, 06:09 PM   #6
Rewards Points: 180
Check this out..'
Quote from the video.
Out of the millions of miles that LP has sold they never had one moister claim
Then what did they shell out $486,000,000 in claims for? That kid should do his homework before including such statements in his pitch.
I do think the LP looks better than the Hardie. Keep it well painted and you should be fine.
LP did always blame the installers and lack of homeowner maintenance as the problem with their product.
Old 08-12-2013, 06:15 PM   #7
I think he means with this product.
Old 08-12-2013, 06:31 PM   #8
Rewards Points: 180
He didn't say "Smart Side" he said "LP". LP is a much bigger word(s).
That aside I tend to forget about the regional thing. All of my experiences with LP were on the Pac NW Coast where for at least 3 months a year everything is wet and never gets a chance to completely dry out.
Old 08-12-2013, 06:37 PM   #9
And that guy is from here- and the hail thing is a real issue. Originally I was going to go with vinyl , Old house (1918) getting a POS garage replaced. But now considering the upgrade.
Sounds like neither is perfect- pros and con's of both. Hoping for some more input of those who have dealt with this product itself.
Old 08-12-2013, 06:54 PM   #10
Rewards Points: 180
Then I'll say no more other than I'll make sure I have a piece of smart side in my hand tomorrow to begin the bucket test.
Just have to do it now.
EDIT: I'll be sure to throw a piece of Hardie in the stew too.
Old 08-12-2013, 08:14 PM   #11
LOL- You do the test- and keep me informed of the results- not getting the ga-rage done until spring!
Old 08-13-2013, 07:30 PM   #12
Rewards Points: 180
The stew is cooking Brush...Smart Side was 3/8" going in...Will report back in a week.
Old 08-13-2013, 09:55 PM   #13
Cool!
Old 08-14-2013, 07:16 PM   #14
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
they'll both turn to mush if left in the water.
they both have their own pros and cons. smart side is easier to install if you havent done siding before.. just get hte first course perfectly level and set each row on top as it has the plastic strip on the back.. harti has to installed by a gauge block or to a chalk line every course to keep even spacings
woodworkbykirk is offline   Reply With Quote
Old 08-14-2013, 07:30 PM   #15
Rewards Points: 180
I have no doubt that the Smart Side will turn to mush in short order. It grew a 64th in just a day.
I've done the Hardie test before (15 years ago) and after 6 months it looked the same.
Now, Square D Combo AFCI Breaker Trips Opens w/No Load Side Connections QO120CAFI mysterylectric Electrical 14 10-27-2013 03:51 PM
"smooth" side on hardie backer amakarevic Building & Construction 2 04-12-2011 11:43 AM
Maytag Side by side dannykapp Appliances 25 02-27-2011 10:25 PM
GE side by side leaking chrisn Appliances 0 08-16-2010 04:48 AM
GE Side by side water dispenser not working cfinchapex Appliances 3 09-19-2009 11:39 AM
