Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-06-2011, 10:24 PM   #1
Hanging bells from ceiling
Hi all
I need to figure out how to hang a couple of 30lb decorative brass bells from the ceiling on the front porch. I think an alternate maybe to use a cantilever bracket from the walls instead. My main concern is not having these drop on someone's head so want to make sure I am using the right equipment.
Cheers
Kkakar is offline   Reply With Quote
Old 08-06-2011, 10:40 PM   #2
Lag screw with hook or eye hole into a framing member into the ceiling.. Use one large enough and pilot a hole. I would guess 3/4- inch.. You would have to use more attachment with cantilever bracket. But you would have to consider how you want it to look also, bracket might look better. Take a picture I will tell you what I would do..
Oh.. into foam ceiling?? I guess if you cant get to a framing member you will have to attach it to something structural, not the the foam obviously..
Omegaroofer is offline   Reply With Quote
Old 08-06-2011, 10:53 PM   #3
Thanks for the prompt reply omegaroofer! Sorry for the typo in the title "foam" should read "from"!
Old 08-06-2011, 10:59 PM   #4
Not a problem, just sitting at the computer doing proposals. Im here every day after 5pm in and out until about midnight.. lol
Old 08-07-2011, 10:19 AM   #5
RFN-4A-LVN
Roofmaster417's Avatar
Without trying to sound like a butt.Please post some pix of the 30lb bells.After they are hung.
I have never seen a 30lb brass bell hung on a porch before.And what are your use for the bells?
Seriously.
Roofmaster417 is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
hanging ceiling drywall in a basement charlie bob Building & Construction 4 03-11-2011 10:49 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Thermostat VS Ceiling fan MrShadetree0222 HVAC 38 01-23-2010 04:29 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
