Hail Storm - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-21-2009, 06:38 PM   #1
Rewards Points: 150
Hail Storm
well, my 8 year old roof was damaged in a hail storm along with my siding, 3 cars and pool. I had 30 year archetict shingles on and now insurance wants to replace roof, I cant find the roofer who did the original job and want to know what to look for in a contractor. The last guy was a referral and he did a awesome job. This sucks.. I am in Upstate N.Y.
econdave is offline   Reply With Quote
Old 07-21-2009, 06:47 PM   #2
Check and see if these areas covered by one of our members here are near you.
Servicing the Rockland County cities- Bardonia - Bear Mountain - Blauvelt - Chestnut Ridge - Clarkstown - Congers - Garnerville - Haverstraw- Hillburn - Monsey - Nanuet - New City - Nyack - Palisades - Pearl River - Piermont - Pomona - Ramapo - Sloatsburg - Sparkill - Spring Valley New York - Stony Point - Suffern - Tallman - Tappan - Thiells - Tomkins Cove - Upper Nyack - Wesley Hills - West Haverstraw - West Nyack New York
If so, then contact him @ http://www.advancedroofingnewyork.com/
Tell him that Ed The Roofer referred him.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-22-2009, 05:14 AM   #3
Rewards Points: 150
no, I am west of albany. any advice would be great, what kind of shingles to use, and other info would be great
Old 07-22-2009, 06:14 AM   #4
Residential Roofer
Slyfox's Avatar
I install several brands of shingles, they all have pros and cons.
It's best to find a roofing contractor you feel confident in and than discuss such issues as what brand with him/her.
Ask family members, neighbors and co-workers who they used for their roofing needs.
Look for roofing contractor signs setting in yards around your area.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 07-22-2009, 07:23 AM   #5
MJW
Had to remove something from that..........
MJW is offline   Reply With Quote
Old 07-22-2009, 09:21 AM   #6
Rewards Points: 150
GAF shingles or ownes corning
Old 07-22-2009, 12:36 PM   #7
They both have their legions of contractors who like them.
In my opinion,
Certainteed LandMark 30 AR or Tamko Heritage AR would be neck and neck for first choice.
Then, GAF/Elk 30 year shingles
Then, Owens Corning OakRidge 30 AR, but Not the Duration line. It is only a bit over 2 years on the market and already having reports from other roofing contractors regarding nails rusting out, due to the full length continuous sealant strip, which traps moisture under the shingles.
More important than the material choice, it the references and training of the roofing crew doing the installation and that they upgrade the ventilation and ensure that there is Balanced Intake and Exhaust Ventilation installed.
Ed
Old 07-22-2009, 01:57 PM   #8
MJW
I agree with Ed's list and his order of choices, although shingles vary quite a bit depending on where you are in the country. I have no knowledge of what shingles are like in NY.
I would have to put Malarkey in the top choices also, going by what other roofers have said about them. They should be available being you are up north.
Old 07-22-2009, 04:53 PM   #9
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
In my opinion,
Ed
Interesting. I'd contact Maze and file a claim if their nails are rusting. I haven't seen any issues around here with them, or the other brand of nail. Can't remember the name though.
tinner666 is offline   Reply With Quote
Old 07-24-2009, 04:52 AM   #10
Rewards Points: 150
just got my first estimate and what do you know the contractor is adament about using owens corning duration line of shingles. GAF elk is the better choice? are they available in upstate n.y.
Old 07-24-2009, 08:37 AM   #11
Residential Roofer
Slyfox's Avatar
Yes GAF is available in your area.
My list of top choices varies from Ed and MJW's, Tamko would be at the top pretty much equal to GAF and OC but Certainteed would be toward the bottom of list.
All tho OC's sure nail is newer like Ed said, the solid self sealant strip has been used in their products for a much longer time frame and in my area they have a good rep with minimal failed lines of products, far less then CT or Tamko.
Facebook <> Twitter
Old 07-24-2009, 05:19 PM   #12
Rewards Points: 150
what about the timberline 30 year shingle by GAF is that one o.k.?
Old 07-24-2009, 07:49 PM   #13
Page 198 of this link may help you decide what you're up against
http://www.iccsafe.org/cs/codes/2000...ges/IBC-FS.pdf
"And, thirdly, the surface upon which the roofing material rests is
critical for its performance. Haag Engineering, noted since 1924 for
“providing engineering consulting services related to failures,”
states in their Asphalt Roofing Systems Study Guide (1995), “tests
have shown that an overlay of composition shingles over old
composition shingles is considerably more susceptible to hail-
caused damage than is a composition shingle roof applied directly
to a solid deck.” And, “We [Haag] do not recommend overlays.” "
Old 07-25-2009, 02:24 PM   #14
Rewards Points: 150
does that mean they are good
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Replacing glass in older aluminum storm window gt2003 General DIY Discussions 3 11-26-2008 09:07 PM
To Storm Or Not To Storm... Matthewt1970 Building & Construction 1 09-21-2008 11:37 PM
Storm doors sk8z Remodeling 1 04-01-2008 09:28 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 03:16 PM
