Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 01-03-2012, 05:21 PM   #1
gutters or roof
There is a spot at the back of the house where the rain runs over the top of the gutters, when it rains particularly hard. Subsequently a board on the deck has been exposed to water over the years and now needs to be replaced. This only occurs during heavy rain. The gutter is clean, pitched properly, the flashing is intact. It is a low pitch roof. There are no leaks in the house. My wife insists that there is something wrong with the roof. I don't know what to tell her.
les0011 is offline   Reply With Quote
Old 01-03-2012, 06:06 PM   #2
Exterior Construction
Windows on Wash's Avatar
gutters or roof
Do you have gutter caps? Are the gutters level?
If it is an uncapped gutter and level, you could try put wedge blocks behind that section of gutter to pitch it up to level and catch the water a bit better.
Old 01-03-2012, 06:53 PM   #3
Retired carpenter
gutters or roof
Tell her to get on the roof when it's raining hard and to report back to you.
abracaboom is offline   Reply With Quote
Old 01-03-2012, 07:59 PM   #4
gutters or roof
Old 01-03-2012, 08:11 PM   #5
chb70's Avatar
gutters or roof
Show us a picture.
Complete Roof
chb70 is offline   Reply With Quote
Old 01-04-2012, 12:07 AM   #6
Doing This Way Too Long
gutters or roof
If it's a valley, put up a deflector
OldNBroken is offline   Reply With Quote
Old 01-05-2012, 09:50 PM   #7
gutters or roof
Couple of things:
1) A "Diverter" is an extra piece of aluminum attached to your gutter that sticks up high and catches overshoot in heavy rain. If it is a valley, as OldNBroken asks, then a diverter will help immensely. If you're handy, you can fashion one out of gutter material with tin snips, and fasten it on with gutter screws.
2) It's the roof, but it ain't the roof. The design of the house and roof (low pitch and all) might contribute to the problem, but if the real problem is replacing one deck board every few years ... replace the deck board and call it a day. Your wife can be right and you don't have to spend a ton of dough on the "problem".
Double-A is offline   Reply With Quote
Old 02-10-2012, 10:38 AM   #8
gutters or roof
OK people the problem is in the picture, Kind of. How long is the other gutter that dumps into this one. I would bet too long for the size of downspout coming off this gutter. You need to figure the SF of area that is draining to this downspout and find out if it is big enough. I suspect you will find it is too small. Very common problem most home builders ar more concerned with looks than function. Because what problem would it cause, the gutters to overflow in haevy rains "Who is ever going to pay attention to that"!
cjthedad is offline   Reply With Quote
Old 02-10-2012, 10:49 AM   #9
gutters or roof
Looks like there's no drip cap on the edge of the roofing. A sure what to get deck rot.
A cheap easy fix.
Old 02-10-2012, 10:46 PM   #10
RFN-4A-LVN
Roofmaster417's Avatar
gutters or roof
Ummm.,.,Did I miss something ?.,Where is the picture of the OP's house ?.,The only one I see is W.O.W's picture demonstrating what wedge blocks behind the gutter are.
Roofmaster417 is offline   Reply With Quote
Old 02-10-2012, 10:48 PM   #11
gutters or roof
Ha it was late and I was tired, sorry I missed that.
Old 02-10-2012, 11:53 PM   #12
gutters or roof
Guess she could get up there and check it out while she is warming up the car for you in the morning.
guest is offline   Reply With Quote
Old 02-11-2012, 12:59 AM   #13
RFN-4A-LVN
gutters or roof
I would not provoke her.,He will be setting in front of the computer reading your reply.Then he will chuckle and she will sneak up behind him to see whats so amusing to him.,read it then connect her shoe to the side of his neck right below his left ear.hahahahahahaha.,
Btw.,just playing with the OP.
Old 02-11-2012, 01:19 AM   #14
RFN-4A-LVN
gutters or roof
No worries my friend.I thought it was just part of my routine of missing a post.I have been on a roll with missing important parts of a post lately.It is nice to finally break the spell.hahahahaha
The Following User Says Thank You to Roofmaster417 For This Useful Post:
rossfingal (02-11-2012)
Gap between roof and gutters. ben4345 Roofing/Siding 4 10-12-2011 06:17 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
roof leaking behind gutters bigg_red1 Roofing/Siding 19 04-20-2011 06:06 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
