Gutters - Proper Way To Route Water - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-26-2011, 09:38 PM   #1
Gutters - Proper way to route water
I am having gutters done and they are saying they would like to do one less downspout in the back of my house and instead route the water from my upper roof to my lower roof.
If I have the option of having a downspout from the upper roof to the group or routing it over a lower roof what would you do? Is it bad to route it onto a lower roof, seems like a lot of my neighbors do.
zone is offline   Reply With Quote
Old 10-26-2011, 10:43 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Dumping water from one roof to another is not recommended.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Tom Struble (10-27-2011)
Old 10-27-2011, 12:03 AM   #3
Rewards Points: 268
Where do you live? Do you get a lot of snow or very heavy rains?
packer_rich is offline   Reply With Quote
Old 10-27-2011, 02:55 PM   #4
I live in Chicago.
Old 10-27-2011, 04:18 PM   #5
Rewards Points: 2,238
Do you want the more "time consuming" - "material consuming" way?
Have them run a separate downspout.
If you want to do it the next "best" -
downspout across the roof below, with an elbow dumping into the
lower gutter.
(Not my choice)
rossfingal
rossfingal is offline   Reply With Quote
Old 10-27-2011, 05:07 PM   #6
RFN-4A-LVN
Roofmaster417's Avatar
I agree with Tinner,,But I would consider it if the upper level was 1/3 of the length of the lower and you were replacing the 5" with 6" gutters.
Roofmaster417 is offline   Reply With Quote
Old 10-28-2011, 11:37 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
Lump me into the category of another person that doesn't like dumping huge volumes, at high velocity, of water onto a lower roof.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Lost Hot water pressure brile Plumbing 11 11-28-2010 03:59 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Basement water heater "discharge line" proper draining ideas/options? ohman Plumbing 5 06-24-2009 02:22 AM
