Gutters Leaking With Drip Edge. Help! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2010, 09:57 AM   #1
Gutters leaking with drip edge. Help!
I bought my first home last year and noticed that during rain (especially heavy rain), a lot of water gets behind my gutters. It would appear like the water flows to the edge of the shingles, rolls up underneath and flows down the drip edge which is flush with the fascia, going behind the gutters. Obviously, the fascia is not in the best shape and I plan on getting the roof done within the next year or two. If anyone has any information on what I can do to prevent further leaking of the gutters, I would extremely appreciate it. The current drip edge is nailed in under the starter row of shingles and I cannot pull it up.
Here are a couple pictures, they suck but its the best I could. (I know I need to clean them!)
Thanks for your help!
Gutters leaking with drip edge. Help!-img_2335.jpg   Gutters leaking with drip edge. Help!-img_2336.jpg
hansmike is offline   Reply With Quote
Old 05-14-2010, 10:08 AM   #2
Knows everything but that
Rewards Points: 150
Im not a genius but Id start with cleaning those things out.
JakAHearts is offline   Reply With Quote
Old 05-14-2010, 10:37 AM   #3
Pretend they're clean and flow properly like they normally do. Its not a problem with overflowing - Verified during last HEAVY rain.
Old 05-14-2010, 06:02 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
It looks to me like the gutters are standing proud of the fascia. I'm not familiar with the hangers used here.
The solution I see (I often have to do this with half round gutters) is to get a "Z" channel fabricated that will slip behind the drip edge flange, extend almost horizontally far enough to clear the back of the gutter, and then down into the gutter.
If I were re-roofing and saw this, I'd extend the shingles a little further past the drip edge.
seeyou is offline   Reply With Quote
Old 05-19-2010, 12:45 PM   #5
Rewards Points: 1,452
Originally Posted by seeyou View Post
... were re-roofing and saw this, I'd extend the shingles a little further past the drip edge.
Could you install a strip of new shingle along the entire edge, under the last existing shingle and overhanging the gutter more?
Adding perhaps just one inch to the overhang. Enough to clear the existing roof edge so it acts as the new primary drip edge.
Glued its entire length instead of in spots, to minimize water roll up between it and the last existing shingle.
AllanJ is online now   Reply With Quote
The Following User Says Thank You to AllanJ For This Useful Post:
MARY YNIRIO (05-30-2010)
Old 10-09-2010, 11:37 PM   #6
Reasoned's Avatar
Amazing pics! Looks just like our house. (1944) same issues, same hangers.
Thanks for posting this.
Reasoned is offline   Reply With Quote
Old 10-10-2010, 07:02 AM   #7
Chicago, IL
Michael Thomas's Avatar
Drip edge extender:
http://www.egutter.com/s.nl/it.A/id....&category=-110
is a stock item a most roofing supply houses.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Ice and Water Shield under drip edge? sutterml Roofing/Siding 10 07-11-2011 06:04 AM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 09:25 PM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 11:49 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-03-2008 12:00 AM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
