Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-23-2010, 11:20 PM   #1
Gutters and Gutter Sealant
When is it really too cold to do any work with the gutters such as replacing downspouts or sealing miters?
What is the lowest temperature you would apply Geocel 2321 (I would look at the spec sheet online, but their webpage was not working)?
I think it's tack free in 18 hrs and full cure 5 days, but realistically how long do you have before you can have rain?
handy man88 is offline   Reply With Quote
Old 11-24-2010, 07:18 AM   #2
Shut in w/o Home
seeyou's Avatar
Application is 0F to 140F. I don't think I'll be using any if it's 140F outside.
http://www.geocelusa.com/core/prdb/p...eet_pdf_10.pdf
seeyou is offline   Reply With Quote
Old 11-24-2010, 09:05 PM   #3
Yeah, I think I read on the tube that they recommend you putting the tube in some warm water or body heat before application, but I question whether it will level and cure as fast in colder weather, especially below freezing.
Gutter installation questions Homerepairguy Roofing 7 03-15-2012 11:22 AM
Gutter covers, good or bad jeweler Roofing 2 03-04-2010 01:39 PM
Leaking Gutters fripster Roofing 5 02-13-2010 09:25 PM
"Frozen" Gutter Leak cougar01 Roofing 19 02-10-2009 07:07 AM
Box Gutters Fix or Aluminum? jonathan03 Roofing 4 01-01-2009 01:42 PM
