Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 06-08-2010, 12:59 AM   #1
gutters for butterfly roof
Hi all you experts!
I would like some advice on how to put in a gutter system for a butterfly roof, the kind with a valley in the middle. Diagrams, good sources for supplies ie. scuppers etc., advice from anyone who has done this before; all advice very welcomed.
neophyte buildr is offline   Reply With Quote
Old 06-08-2010, 09:24 AM   #2
I would use a standard 4 inch residental gutter,preferable seamless.The middle section can be straight or level.The left and right runs should drop according to the lenght of the run.Down spouts should be at each end of the left and right runs.Depending on the amount of water running off the roof you may want to consider 6 inch gutters.Scuppers drains are used on flat roofs where the roof meets a wall.
Ron Smith Const is offline   Reply With Quote
Old 06-08-2010, 09:52 PM   #3
Tom Struble's Avatar
pics? when was the house built? was the previous scupper set up working?whats the roof material?
Tom Struble is offline   Reply With Quote
New roof: GAF v ShingleVent II, warranty, gutters? soubriquet Roofing 8 08-01-2010 11:17 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
