Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-15-2010, 07:19 PM   #1
Rewards Points: 81
Gutters
I plugged up my downspout and filled my gutter full of water with a garden hose. The gutters began to overflow out the back of the gutter and not over the front lip. It's an older home, and my guess is that the fascia board is not perpendicular to the ground. If needed, can I shim out the back of the gutter at each hanger so that the water overflows the front. I haven't confirmed with a level, but if the gutter is tilting back toward the fascia, it is only a small amount. There is drip edge installed that goes down at least half way into the gutter.
cougar01 is offline   Reply With Quote
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 09:25 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 06:42 AM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 01:42 PM
Advice on installing gutters on slanted fascia notfromaroundhere Roofing/Siding 3 12-27-2008 05:34 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 10:36 PM
