Gutters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-29-2016, 01:23 PM   #1
Rewards Points: 588
Gutters
I have lost all hope for my gutters at this point. They have always overflowed with heavy downpour rain. I have pitched them a little steeper on each side to no avail. I have disconnected them from the underground drain pipes assuming they must be clogged or overwhelmed. I thought that did the trick but we had a thunderstorm last night and it was raining hard and the gutters were once again overflowing and causing a small waterfall that's destroying my flowerbeds and has caused me to have to buy tons of dirt to put underneath my porch (still working on that). I have even had a handy man check out my gutters to see if something else was wrong but he said they looked good and we're pitched like they should be. I have basically done everything short of replacing the gutters all together. What else can I do? Will I just have to suck it up and replace them with larger gutters?
nikeman is offline   Reply With Quote
Old 04-29-2016, 01:37 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Re: Gutters
What size units do you have. I have never seen a properly laid out gutter plan overflow when you are talking about 6" seamless units.
I haven't seen 5" overflow either, but 6" just gives you that additional fudge factor.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Gymschu (04-29-2016)
Old 04-29-2016, 01:46 PM   #3
Gymschu's Avatar
Rewards Points: 244
Re: Gutters
Sounds like you've done everything you can to alleviate the problem. WoW's idea is the best idea of course. 6" gutters almost always take care of any amount of rain that hits your roof.
Were the downspouts taken down and checked? I've found all kinds of stuff in downspouts that caused a plug and an overflow of the spouting. I've found balls, remnants of birds nests, twigs/leaves, maple tree seeds, etc. The last place I worked on (in prep for painting) the HO said the downspouts were fine but they still were getting overflow. So, I removed them and found rubber balls in each of the front downspouts that were causing a blockage. The HO's kids were throwing the balls up on the roof and playing catch. Only thing was they didn't tell mom and dad that the balls got stuck in the gutters and eventually washed down into the downspouts.
Giving us your general location helps us better help you!
Old 04-29-2016, 02:12 PM   #4
Rewards Points: 588
Re: Gutters
I did remove about half of them and they were clear. No clogs in the downspouts. A lot of water comes out of them also. They are the smaller gutters and have been on the house since it was built in 1999.
Old 04-29-2016, 02:13 PM   #5
craig11152's Avatar
Rewards Points: 88
Re: Gutters
Typically 5" gutters have 2x3 outlets and downspouts while 6" gutters have 3x4 outlets and downspouts.
It is possible to put 3x4 outlets and downspouts on a 5"system. That may solve your problem. If you need to go to a 6" gutter the downspouts are reusable and the outlets are only a couple bucks apiece.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
The Following User Says Thank You to craig11152 For This Useful Post:
Old 04-29-2016, 02:16 PM   #6
Rewards Points: 588
Re: Gutters
By that I mean enough of each downspout where I could look up them and see the sunlight all the way up
Old 04-29-2016, 02:19 PM   #7
craig11152's Avatar
Rewards Points: 88
Re: Gutters
They aren't old galvanized 4" gutters are they? If so they need to go away.
Old 04-29-2016, 02:21 PM   #8
Rewards Points: 588
Re: Gutters
They are very flimsy and light so they must be vinyl or aluminum
Old 04-29-2016, 02:23 PM   #9
Rewards Points: 588
Re: Gutters
The downspouts used the smaller of the 2 adaptor options at home depot to connect them to the flex tube. 3x4 maybe? 2x3? I can't remember but one was way to big to fit my downspout
Old 04-29-2016, 02:23 PM   #10
craig11152's Avatar
Rewards Points: 88
Re: Gutters
It isn't hard to tell the difference between vinyl and aluminum. Can you take some pictures and post them?
Old 04-29-2016, 02:25 PM   #11
craig11152's Avatar
Rewards Points: 88
Re: Gutters
measure your downspout width and depth. They should be close to 2x3 inches
Old 04-29-2016, 02:29 PM   #12
Rewards Points: 588
Re: Gutters
They gotta be aluminum. I remember sparks when I replaced a few nails with screws while repitched them. Lol
Old 04-29-2016, 02:30 PM   #13
Rewards Points: 588
Re: Gutters
I'm currently at work but they are the smaller gutters you can buy.
Old 04-29-2016, 02:30 PM   #14
craig11152's Avatar
Rewards Points: 88
Re: Gutters
As I mentioned earlier you can take your 2x3 outlets out, cut a bigger hole and put 3x4 outlets in your gutters. Then replace all your 2x3 downspouts with 3x4. That will double the capacity of your downspout system.
Old 04-29-2016, 02:36 PM   #15
Rewards Points: 588
Re: Gutters
Would that do the trick you think? Wouldn't have to replace the entire gutter? I'd only want to do that to 4 downspouts since the other 2 are connected to maybe 1.5' sections of gutter each on either side of the porch.
Type of Gutters? Alumifab Roofing/Siding 13 12-18-2015 12:41 PM
new drip edge over existing gutters scheiman Roofing/Siding 1 06-05-2010 08:44 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 09:25 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 01:42 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 10:36 PM
