Gutter System Help. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-20-2010, 06:39 PM   #1
Gutter system help.
well i am planning to replace our gutter system and I hope you guys could help me choose the best material for our gutter system. I am planning to use aluminum but i think it cost too much can you give me a better option? thanks
yellowranger is offline   Reply With Quote
Old 11-20-2010, 07:54 PM   #2
The less expensive option up front would be one of the snap together PVC systems, buttt, you get what you pay for.
As far as competing sheet metal systems, steel, anodized, copper, kynar 500, etc..., you would probably wind up paying a significant premium for any of those alternatives.
.032 gutter coil stock really does give you the most bang for your buck.
What do you consider, "Too Expensive"?
I consider doing the job correctly with the most efficient materials and workmanship the first time the best expenditure of your investment.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-22-2010, 11:40 PM   #3
thank you so much dude. it' will really help a lot. right now im checking on the services of www.easyfall.com.au... thanks
Old 11-23-2010, 12:04 AM   #4
shop around. i found that in my area a company would come out and hang seamless for barely more than buying snap together cost. i have a 1985 ranch home and wound up with 2 50ft runs, a 10ft run and 5 downspouts all installed seamless galvanized for $400
racebum is offline   Reply With Quote
Upgrade old Rheem Split System fredm54 HVAC 7 05-15-2012 02:04 PM
New system, are my ducts adequate? civiltoatee HVAC 67 10-19-2010 04:06 AM
New HVAC System Recommendations shwank HVAC 14 10-12-2010 02:15 AM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
Carrier AC/Heat pump system help!! Partsman41953 HVAC 5 09-26-2010 05:54 AM
