Gutter Joint Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-26-2013, 03:34 PM   #16
Lord of Slums
Rewards Points: 1,974
http://www.acehardware.com/product/i...LAID=332044012 All else falls these work alright. Bigbox seem to have the longest elbows. If you want a longer elbow you will have to build one. Buy yourself a 10 foot section of 2x3 downspout and cut a small piece off, slip the elbow into the downspout piece going down. Run a screw or two into the small piece of downspout to join the seams. Otherwise on small pieces the seams will pull apart.
mj12 is offline   Reply With Quote
Superior wall joint leaking buckeye1979 Concrete, Stone & Masonry 1 04-26-2012 07:23 PM
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 11:22 AM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 04:57 PM
Leaking around joint of PVC pipes in attic themadcatter HVAC 10 12-18-2007 10:29 AM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 01:29 PM
