Gutter Joint Leaking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-22-2013, 08:27 PM   #1
Rewards Points: 208
as you can see from pic, this gutter connection leaks. how do i fix it? this was installed before i bought the house.
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 05-22-2013, 08:41 PM   #2
Doing This Way Too Long
Rewards Points: 532
Your bigger problem is going to be all the debris coming down that vertical on the right and hanging up on that thing and creating a very hard-to-remove clog in your downspout.
Besides that, best way to seal that thing up would be clean and dry and a good gutter sealant.
OldNBroken is offline   Reply With Quote
Old 05-22-2013, 08:47 PM   #3
Rewards Points: 13,960
Please back up and take another picture so we can see why someone thought this was a good idea to tie into the sdie of a down spout.
That's a first for me.
Old 05-22-2013, 08:48 PM   #4
Rewards Points: 532
LOL, me too
Old 05-23-2013, 07:45 AM   #5
Rewards Points: 208
see updated pictures in first post. how would you fix that leak? obviously, there should be another downspout for that large section of roof.
Old 05-23-2013, 09:01 AM   #6
Rewards Points: 2,240
If the elbow that extents into the downspout - is too long into the downspout - that could create a problem.
Unscrew it and check.
You could put a "wye" there.
Or - another downspout.
"RF"
rossfingal is offline   Reply With Quote
Old 05-23-2013, 09:39 AM   #7
Lord of Slums
Rewards Points: 1,974
The cheapest way is to buy a funnel, the whe's are around 40 bucks. I would connect them underground. I love when people tie the downspout into the end cap of the lower gutter.
mj12 is offline   Reply With Quote
Old 05-23-2013, 09:42 AM   #8
Roofmaster
Rewards Points: 2,210
I would remove them both, slope the gutters the other way and put a downspout on the end of each run on opposite ends of the home. Having downspouts right in the middle of your home is not very attractive.
The Following User Says Thank You to jagans For This Useful Post:
mj12 (05-23-2013)
Old 05-23-2013, 03:52 PM   #9
Rewards Points: 208
what type of funnel and where would it go? the best solution is what jagans said, but i don't have the budget for that fix now.
Old 05-23-2013, 07:02 PM   #10
747
registered
747's Avatar
Rewards Points: 534
I have never seen anything like this. Your going to need some good heavy duty sealant
747 is offline   Reply With Quote
Old 05-23-2013, 07:13 PM   #11
Rewards Points: 652
http://www.guttermaterials.com/Downspout-Funnel.html
Cheap, easy and quick repair. You will want to replace the pipes at the same time, of course.
PatChap is offline   Reply With Quote
Old 05-23-2013, 07:19 PM   #12
Lord of Slums
yeap, that is the funnel. That much of a budget you can make them out of old pieces of flashing. I think they are 3 dollars at the bigbox. Cut the main downspout near where the side discharge enters, pull side pipe into the funnel then cut the main downspout so they all discharge into the funnel together. At this point I would say, pull that top strap, pull the downspout away from the wall and seal all around that downspout seam with some cheap chalk that comes in its own tube.
Old 05-25-2013, 05:03 PM   #13
Rewards Points: 208
where can i find these longer elbow A? these have 7 ridges on the side while the ones at home depot have 6.
Old 05-25-2013, 10:30 PM   #14
Lord of Slums
Is this a repeat question? I noticed the forum does strange things with the posts. If you are asking this question again, did we not answer it the first time?
Old 05-26-2013, 12:50 PM   #15
Rewards Points: 208
sorry, i didn't get an answer on where to buy that longer elbow A from that other thread.
Superior wall joint leaking buckeye1979 Concrete, Stone & Masonry 1 04-26-2012 06:23 PM
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 10:22 AM
PVC Sprinkler Leak at T Joint D2D2 Landscaping & Lawn Care 3 08-26-2010 03:57 PM
Leaking around joint of PVC pipes in attic themadcatter HVAC 10 12-18-2007 09:29 AM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 12:29 PM
