Gutter Install Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-02-2010, 05:01 PM   #1
Gutter install question
I am installing a ~30ft straight run of gutter on the back of my house. I am a bit concerned about how to attach it and what hangers to use. The shape of my fascia makes me believe I can't use conventional hangers and may need under-shingle mounts. Here are some pictures. Let me know what you think. Thanks!
boostedty4 is offline   Reply With Quote
Old 04-02-2010, 06:10 PM   #2
kwikfishron's Avatar
Rewards Points: 86
I always use spikes, they hold. I’ve had problems finding good continues gutter parts at hardware and box stores. Look in the phone book for a HVAC sheet metal shop that also installs gutters, most of them do, then go to the shop with your picture and they should fix you up.
kwikfishron is online now   Reply With Quote
Old 04-03-2010, 12:38 AM   #3
Commercial Roofing
AaronB's Avatar
You can use the Tbar hangars which, like you said, mount under the shingles, and allow the gutter to hang.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Laminate Install Question margog85 Flooring 2 03-20-2011 05:18 PM
Humidifier Install Question - Inside A Coil OK? dwolek HVAC 1 12-21-2009 01:37 PM
culture stone install question raven27 Building & Construction 4 11-02-2009 11:31 AM
New humidifier install question wlee69 HVAC 1 09-25-2008 12:52 AM
Gutter Elbow Question handy man88 Building & Construction 6 09-19-2008 07:54 PM
