Gutter Heaters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-18-2007, 10:11 AM   #1
Rewards Points: 672
Gutter Heaters
Has anyone had any experience with a gutter heater? I have an east facing gutter overflows with water and freezes in the winter and then when it thaws it melts and drips all over our front porch and creates a skating rink. I was thinking about installing a gutter heater that someone told me was available that might help. Has anyone used one? Do they work? If so, where can I get one? Home Depot, Lowes?? Thanks for the help!
kennykenny is offline   Reply With Quote
Old 12-18-2007, 05:12 PM   #2
Why does it overflow?
Is the downspout plugged?
redline is offline   Reply With Quote
Old 12-18-2007, 05:20 PM   #3
Rewards Points: 672
no, the gutter just gets filled with Snow, rain, freezing rain etc. I live in an area in which the temp. may not get above frrezing for a number of days straight so the elements don't have an opportunity to melt....
Old 12-18-2007, 06:59 PM   #4
Sr. Development Engineer
DrDave's Avatar
A company called chromalox makes strip heaters. I have researched these for use inside Din Rails in our Control Systems. Check them out, I think they might have something for your problem.
www.chromalox.com
Last edited by AtlanticWBConst.; 10-25-2008 at 09:52 PM. Reason: Old Web Link Removed AGAIN
DrDave is offline   Reply With Quote
Old 12-19-2007, 03:40 AM   #5
Do you have adequate insulation in the attic?
http://www.roofmelt.com
Old 12-20-2007, 08:20 AM   #6
Rewards Points: 672
I have blown in additional insulation in the area of concern. It is in an area in which there is not a tremendous amount of access. Thanks !
Old 10-21-2008, 08:38 PM   #7
Mind is in the gutter
Snow Guards
You might also consider installing snow guards. They're less hassle than a gutter heater.
Gutter Guy is offline   Reply With Quote
Old 10-25-2008, 11:57 AM   #8
Rewards Points: 672
What are snow guards? Are they available at Home Depot/Lowes? Is there a website on them? Thanks!
Old 10-25-2008, 12:24 PM   #9
They are small plastic or metal protrusions, which get attached to the lower edge of the roof to prevent snow from sliding off, which is a particular concern with metal roofing.
Google Snow Guards or Snow Gems.
Ed
Ed the Roofer is offline   Reply With Quote
Old 10-25-2008, 12:56 PM   #10
Snow Guards
That's right. We sell them on our site http://www.guttersupply.com/p-snowguards.gstml and you can find at least one type at Home Depot http://www.homedepot.com/webapp/wcs/...ctId=100388308.
I'm not sure these will exactly solve your problem. They're mostly designed to keep snow from cascading down your roof and causing damage. But they will help keep snow from clogging your gutters. They are zero help against freezing rain.
Last edited by Gutter Guy; 11-08-2008 at 12:05 PM. Reason: I messed up the links earlier
Old 10-25-2008, 05:41 PM   #11
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
As far as the original question goes, we use the gutter cables and install them. You can get one of the types available at HD or Lowes. That type is a single temperature cable. You should always install it in double runs. That means all areas, including the downspouts, should have 2 cables in it. That's because a single run will only melt about a quarter sized hole and then it will "igloo" over.
The other type available, which is more expensive, is called self-regulating cable. It will change temperature with more severe weather. That way it uses less energy at 30* then at 0*.
You can even take them a step further and install a sensor to activate the system automatically with low temps and moisture. It will also shut off when either theh temps rise above 38* or the moisture stops.
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 10-25-2008, 06:08 PM   #12
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
from the chromalox site.
http://www.chromalox.com/productcata...ils.aspx?p=317
I did not read up on any particular cable on that site but I would strongly suggest the self regulating cable. Theoretically you do not even need a thermostat because it is (wait for it)... self regulating and will not heat if the ambient temp is above the designed temp.
It is more expensive but it also prevents unneccessary use. Many of them can also be crossed where the non self regulating cable cannot. You will find that little bit of a difference can make a big difference in installation sometimes.
there are many brands out there. Be sure to follow directions for installation and terminations exactly as the manufacturer lists.
and be sure to use it in the down spout. That is often the root of the problem.
Old 10-25-2008, 08:07 PM   #13
Rewards Points: 150
Precisely the brand we use and install.
Old 02-02-2011, 04:53 PM   #14
Water leaking in from ice-dams
Hi, I was wondering if the Chromalox gutter-heater (and roof snow/ice melter) was what you are referring to when you talked about the self-regulating cables? I priced-out THERMWIRE 6-1CR EZP Heating Cable - Roof & Gutter De-Icing - TW6-1CR-EZP at $585.00 but it doesns't tell me anywhere how MUCH cable is included here.
Thanks for all your help in this crazy weather!
istvan_bracz is offline   Reply With Quote
Old 02-02-2011, 05:08 PM   #15
Rewards Points: 150
Hi!
Got your message and I'll contact you in the morning. You are right, it has been non-stop for two weeks...too bad nothing can be done until spring!
The TW6-1CR-EZP you mentioned has a few suffixes but you can get it in 100/250 and 500' lengths. The one you priced (too high) is 100' of SR cable. We are also now carrying a 10 year warranty cable. Chromalox is a 1 year warranty cable.
Tankless Water Heaters Recalled for Repair Due to Carbon Monoxide shimp Plumbing 1 01-22-2008 06:52 PM
Removing Baseboard Electric Heaters gieriscm Electrical 12 11-12-2007 04:59 PM
Freestanding/portable safe home heaters?? sugarmama HVAC 5 10-30-2007 08:23 PM
facia repair and gutter boman47k Carpentry 2 09-11-2006 07:06 AM
