Gutter Headers Or Scuppers - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-13-2010, 06:11 PM   #1
gutter headers or scuppers
what type of business sells gutter collectors or scuppers? I found specialty stores that sell fancy copper ones but I just want something simple that works. Can one be built using gutter accessories or parts?
eatmysawdust is offline   Reply With Quote
Old 06-13-2010, 06:29 PM   #2
kwikfishron's Avatar
Rewards Points: 772
Your local HVAC/ Gutter/ Sheet Metal Shop.
The one business usually does all of the above and can make anything you want.
kwikfishron is online now   Reply With Quote
Old 06-14-2010, 05:05 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Copper or galvanized are the materials of choice for items like this since those materials can be soldered leak free. Aluminum leader boxes are available. Since labor cost far outweighs the material cost on an item like this, using a material other than copper doesn't reduce the price much, which is why you won't see a great variety of product in other materials.
I'll probably get in trouble for this, but I know of several leader boxes for sale for around $100 each. I manufacture one of them. I won't say which.
Box1 Box2 Box3
seeyou is offline   Reply With Quote
Old 06-14-2010, 08:20 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
ill take 2
Tom Struble is offline   Reply With Quote
Old 06-14-2010, 08:44 PM   #5
Whats the little triangle do on the front ?
...choice are OK
Old 06-14-2010, 08:50 PM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Overflow. If used with a scupper through the back, the bottom of the scupper should be slightly higher than the overflow so water can still leave the roof if the downspout clogs.
Old 06-19-2010, 10:54 PM   #7
We also call them "Header Boxes" and they're really easy to fabricate. You can certainly buy them from any decent Sheet Metal fabrication Shop, or a roofing supply house. You may be able to google Header Boxes or Scuppers and search for a pattern. The material would be very inexpensive, you can pop rivet them or spot weld them, then simply caulk from the inside any seams. even copper ones using "Vulcum"
getrdone is offline   Reply With Quote
Squirrels chewing the gutter guards... gshock Roofing/Siding 3 06-29-2016 12:24 PM
Rain gets underneath gutter Heimwerker Roofing/Siding 8 12-28-2011 12:59 AM
Gutter leaks after roof replacement Jim F Roofing/Siding 6 04-16-2010 08:42 PM
Rain gutter slopes the wrong way ovahimba Roofing/Siding 2 12-20-2009 03:56 PM
"Frozen" Gutter Leak cougar01 Roofing/Siding 19 02-10-2009 06:07 AM
