Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-02-2012, 03:26 PM   #1
Gutter Guards/Filters
i saw these gutter filters on homedepot and i am wondering if these really work for keeping leaves and large debris out?
do you guys recommend it or something similar?
http://www.homedepot.com/Building-Ma...5#.UBrSV6P5914
Scully is offline   Reply With Quote
Old 08-02-2012, 04:14 PM   #2
"Nail-Bender"
No - don't use those!
They clog too!!
rossfingal
rossfingal is offline   Reply With Quote
Old 08-02-2012, 08:30 PM   #3
I can not see by that picture but if it's the ones that also have the fine nylon mesh as well as those big holes, I've had great luck with them.
DO not use the ones with just the big 1/4 holes and no mesh. They catch every leaf stem and will not keep out pine needles.
Old 08-03-2012, 09:17 AM   #4
Exterior Construction
Windows on Wash's Avatar
+1
You might as well keep the money in your pocket. They do not work.
Get a proper cover and be done with it once and for all.
Old 08-03-2012, 05:45 PM   #5
"So I Re-Wired It"
MisterZ's Avatar
I have installed plenty of these over the years.
I always tell the customer they have 60% success rate.
If you only have a few large leaf trees, such as maple, you may be ok.
My personal recommendation, dont bother. Screens are a hit-or miss item.
Some have good luck, others not so good. It may pay to just have someone clean your gutters twice a year.
Depending on the size of your house it may run about $100-$200 each time.
I have stopped selling these screens several years ago. Alcoa makes a good product called leaf releif.
Knowledge is Power, but 240v can Keel You!!
MisterZ is offline   Reply With Quote
Old 08-03-2012, 10:46 PM   #6
I install the wire mesh ones normally. It really depends on what kind of trees you have in your yard. Pine trees, maple trees and trees that have tassels will get into just about any of them.
Bellboy is offline   Reply With Quote
Old 08-03-2012, 11:26 PM   #7
so there's no gutter filter/guard on the market that works 100%? i guess there's no way around cleaning the gutters.
Old 08-04-2012, 12:31 AM   #8
"So I Re-Wired It"
MisterZ's Avatar
I have had great success with Alcoas Leaf Relief. However, if you have pine needles youre better off without covers.
As you can tell, this subject is controversial.
Gutter Protection Gutterstress Roofing 5 08-08-2012 12:17 PM
Gutter installation questions Homerepairguy Roofing 7 03-15-2012 11:22 AM
Yankee gutter resurfacing options miamicuse Roofing 24 01-06-2012 09:20 AM
Gutter mounting options. Hidden hangar vs SnapLock vs ?? frascati Building & Construction 5 09-30-2011 12:14 PM
"Frozen" Gutter Leak cougar01 Roofing 19 02-10-2009 07:07 AM
