Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-02-2012, 06:45 PM   #1
pjm
Gutter Guards
I have a quick question about gutter guards. I just got my roof and gutters replaced and wanted to get the guards to help keep me from having to clean them out all the time, but I only had so much to spend. I've read about raindrop and leaf solutions, but I got a guarantee with the gutters and I think screwing into it would void it? I was looking at the inserts and one question I had is do they freeze in the winter? They look to work pretty well, but I want to make sure they don't freeze solid and cause problems for me in the winter. Any thoughts or ideas would be great.
Thanks in advance.
pjm is offline   Reply With Quote
Old 09-02-2012, 08:39 PM   #2
Bombastic Idiot
notmrjohn's Avatar
Gutter Guards
Check with manufactorer and installers on warranty.
" They (inserts) look to work pretty well" Well no they don't. I've tried all sorts. But then no guards work really well. They all work, ...well...sorta. Even those one piece leaf excluding ones work sorta. And they can't handle a Texas gully washer, no matter what they say. The leaf ejecting ones don't eject it all. Any thing you put over or in your gutter is going to be a place where leaves, snow and ice can accumulate, as it can in an empty uncovered gutter. Leaves don't all blow off or out,when they get wet they pack down creating places for more leaves,snow ice.The gutter itself can be completly clean but ice,snow, leaves on top prevent water from passing thru.You get leaf dams and ice dams. Snow and ice can build up in gutter and overflow thru screen and pile up. Debri and ice can build up on steeply slanted screens. The best add ons I've found are steeply slanted fairly open grid with higher ridges running across the gutter, even then leaves can get between the ridges, stems stuck in grid. I can't find them any more anywhere. Ice is not a problem here usually, at least not lasting long enuff to be gutter and roof wise, If that is a major concern of yours I would stay away from any flat topped guard, or brush type insert.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
The Following User Says Thank You to notmrjohn For This Useful Post:
daluu (09-09-2012)
Down pipe guards or gutter guards Laurence Roofing 7 04-07-2013 12:58 AM
Gutter installation questions Homerepairguy Roofing 7 03-15-2012 11:22 AM
What are your guys' opinions on gutter guards? strategery Roofing 9 12-27-2011 10:35 PM
gutter guards MLMIB Building & Construction 6 03-07-2011 11:48 AM
Squirrels chewing the gutter guards... gshock Roofing 1 04-12-2009 01:47 PM
