Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-03-2010, 04:51 PM   #1
Gutter covers, good or bad
I live in the hills (8500') and am getting snow that turns to ice in my gutters. Currently I pull much of the snow out of the gutters when I use a snow rake on the eave overhang. I have heated tape in the gutters. This combo works, but I'm trying to simplify. If I put those leaf guard devices on the tops of the gutters then the show would not fill the gutters. I could just pull the snow off the eaves with the broom and over the gutter covers. I am hoping that as the snow melts off the roof it will run into the gutters and the heat tape will continue to work as before. However, what I don't know is if the gutter covers will solve the snow in the gutter problem, BUT create a new one.
Does anyone have experience with this? Will it work?
jeweler is offline   Reply With Quote
Old 03-04-2010, 08:13 AM   #2
There are numerous types of gutter guards. What type do you have installed?
BamBamm5144 is offline   Reply With Quote
Old 03-04-2010, 01:39 PM   #3
At present there are no gutter guards in place. I am considering adding them as a way to keep the snow out of the gutters. However, I heard somewhere that they created more problems than they solved. So I am trying to see if anyone has knowledge whether this will work before I spend the money and the time.
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
"Frozen" Gutter Leak cougar01 Roofing 19 02-10-2009 07:07 AM
replacing gutter apron ponch37300 Roofing 5 07-31-2008 07:25 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing 3 07-02-2008 03:10 AM
Proper way to install gutter flashing? Kasfidan Roofing 3 03-17-2008 01:57 AM
