Gutter Apron At Inside, Outside Corners - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-14-2008, 09:59 AM   #1
Location: 100 miles north of Atlanta, 20 south of Chattanooga
Gutter apron at inside, outside corners
Does anyone have pictures or diagrams, etc, that shows how to install gutter apron at corners?
I am looking for cut and overlap detail to prevent leaks and can't get it in my head how to do this?
Using 4" x 3" .27 aluminum, pitch 10/12, both inside and outside corners.
Any help is greatly appreciated.
Thanks,
Alan
oldgrunt is offline   Reply With Quote
Old 12-14-2008, 09:37 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
no pic but you would mark the top half metal outside edge and cut to the bend,using a speed square follow that mark to lower metal edge(don`t cut),mark the bottom and nip it with the snips(small snip pointing at previous cut,now bend the metal corner between these points,apply sealant 1" from corner/side,and lap rake metal to the corner where eave flashing was bent--on the sides ,cut whatever may hang below the rake edge metal
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 12-22-2008, 08:19 AM   #3
Thanks TRG,
I really value your input.
I think I have it now.
Have a safe day,
Alan
Old 12-22-2008, 05:01 PM   #4
You`re very welcome
Inside corners cracking with new paint n0c7 Painting 8 08-02-2008 02:53 PM
replacing gutter apron ponch37300 Roofing/Siding 5 07-31-2008 06:25 PM
Taping inside corners....one side at a time? yummy mummy Building & Construction 10 07-23-2008 02:23 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 02:10 AM
