Gutter Apron Extension - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-20-2010, 11:17 PM   #1
gutter apron extension
My 1930s bungalow has a hip roof without an overhang. New shingles installed 3 years ago with a drip edge. Water is leaking (I think) from behind the aluminum fascia, down the inside of the wall and dripping off my sill plate into my basement. On this site someone recommended a gutter apron extension to fill gaps between the drip edge and gutter--I do have gaps in various locations. These locations correspond to where water drips into the basement. Three gutter companies have looked at the problem; two suggested installing a gutter apron over the drip edge; one suggested bending the drip edge out away from the fascia. Will either of those solutions work? None of the three companies have heard of gutter apron extensions. BTW, I also had 3 roofing companies look at the problem. An ice dam material was installed with the new roof, and I believe it extends up 3' from the roof edge. The roofing companies couldn't find anything wrong with the roof. Do I need to insist on the apron extension?
steb is offline   Reply With Quote
Old 08-27-2010, 08:31 AM   #2
Rewards Points: 79
If the drip edge is tight to your fascia, either due to installation or possbly the fascia having "separated" a little from the rafter butts it's nailed to, rain water could possibly be "curling" and going behind the fascia. Pictures would be very helpful. An easy fix which I've done on several homes is to fasten a strip of aluminum that goes from up under the drip edge and into the gutter. This is very easily done with K type gutter as you can pop rivit the strip to the back of the gutter.
jackofmany is offline   Reply With Quote
Old 08-27-2010, 03:08 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
to be honest..i never heard of a apron extension either
Tom Struble is offline   Reply With Quote
Old 08-28-2010, 06:29 AM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
We use them frequently. Especially with half round gutters. Maybe that's an item I should sell on the internets
seeyou is offline   Reply With Quote
Tags
gutters , roofing problem
Gutter installation questions Homerepairguy Roofing/Siding 7 03-15-2012 11:22 AM
No gutter apron available in North Georgia?!!? FlyNaked General DIY Discussions 4 03-14-2010 12:26 PM
Installation of gutter apron over existing apron dbosh Roofing/Siding 4 11-13-2009 10:44 AM
replacing gutter apron ponch37300 Roofing/Siding 5 07-31-2008 07:25 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 03:10 AM
