Guidance For Insulating Slanted Ceilings - Cathedral Ceilings - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-10-2008, 11:25 AM   #16
What can I find here?
Winchester's Avatar
Rewards Points: 150
Originally Posted by mdlorenz View Post
I had a thought...
What if I stapled up those baffles the whole run of the roof, from the soffit up to the open attic space, & then foamed it all... That'd get me the most r-value & still maintain the air space....
This was one of the options I read about in my research on knee walls last weekend. The general concensus was that you needed 2" underneath the sheating.
Googled "sheathing knee walls" for some very informative sites. I think you'd be interested in seeing the illustrations in this pdf.
http://www.ibacos.com/pubs/FactSheet-KneeWalls.pdf
Winchester is offline   Reply With Quote
Old 12-12-2008, 12:30 AM   #17
Commercial Roofing
AaronB's Avatar
Baffles are ok. I have done some.
I like the method of nailing 1x2's to the top of the rafters and then nailing 1/4" whatever to them to make a backstop to spray to. I bet (I havent tried tis yet) polystyrene board would work well for this purpose, too. Then spray to that.
Insulation
Air space
Smile on face
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-02-2009, 11:05 AM   #18
I Try
Having the same problem
I found I have the same problem. I am considering putting 2x6 or 2x8 on edge perpendicular to the rafters, over the existing drywall, insulating and putting up new drywall. Does this sound reasonable?
remernorth is offline   Reply With Quote
Tags
cathedral ceiling , foam , foam board , insulation , slanted ceiling
Insulating slanted ceilings (hot roof?) Skydmark1 Remodeling 6 11-05-2007 12:35 PM
