Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-27-2006, 11:29 AM   #1
Grip H Clip roof clips
Our company produces the plastic roof sheathing clips known as Grip H Clip. We are currently developing other products for the construction industry. I was wondering if some of you out there have had an opportunity to try the clips, and if so, had any feedback for me. We produce a clip for 7/16" to 1/2" and a clip for 19/32"-5/8". I welcome the negative as well as positive. I want to make sure that our product is as good as it can be.
homedic is offline   Reply With Quote
Old 03-27-2006, 07:32 PM   #2
MJW
Haven't seen them yet. All I have seen is the metal clips. How are these different and/or better?
MJW is offline   Reply With Quote
Old 03-28-2006, 08:46 AM   #3
We've got a hinged lead in to easily install these on the sheathing. The design allows the clip, once on, to grip the sheathing so the clips can be pre loaded and the next sheet slid in place. No bending or clips falling off. Our customers have commented that the install has allowed them to take 1-2 hours off of the roofing job of an average size house.
We had them tested for strength and deflection and the result was they are stronger than the steel, in some cases more than twice the load bearing strength. The coastal areas have really been using them because they are resistant to corrosion from salt littered humidity. The web site has alot more info. The distributors like the fact that each size clip can cover a range of sizes, so they are stocking less different items.
www.griphclip.com
Old 04-03-2006, 08:08 AM   #4
Commercial Roofing
AaronB's Avatar
Looks like a good idea. Go to the carpenters, too. They do a lot of roof sheathing.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-03-2006, 09:03 AM   #5
That's a good idea, I will.
Thanks Aaron,
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing 5 08-25-2006 08:28 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing 1 01-02-2006 07:01 PM
