Greenhouse Glass Roof Seal? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-13-2010, 06:06 PM   #1
greenhouse glass roof seal?
Hello! I have designed and built this greenhouse. It is covered completely with glass panels from old sliding glass doors. I want to cover the roof as well but thought I would share my idea of sealing the glass panels with you guys and see what you all think or may suggest?
I plan on covering each seam of glass with a strip of blue skin and then a strip of red cedar on top and then drive a rubber gasketed screw through the cedar, and through the blue skin, into the rafters to make a nice tight seal.
Do you think it will seal properly? Do you have any better suggestions?
Thanks!
greenhouse glass roof seal?-greenhouse.jpg   greenhouse glass roof seal?-greenhouse1.jpg   greenhouse glass roof seal?-greenhouse3.jpg
wt timberworks is offline   Reply With Quote
Old 02-13-2010, 06:45 PM   #2
jlhaslip's Avatar
Rewards Points: 2,158
use strips the same thickness of the glass as 'dividers' between the glass panels
use a bead of silicone to bed the glass onto the timber. This will also help as the timbers age/move.
blue skin the adjoining glass panels and trim out with cedar.
I suggest screwing the cedar. Even tempered glass needs changing if your hammer comes out of your pouch (don't ask how I know)
I did 6 tempered flat glass sky lights on a 28 year old log house the same way. only difference was some flashing on the bottom edge because the glass was only 6 ft tall in a 28 ft long shingled roof
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-13-2010, 09:22 PM   #3
I was going to lay strips of blue skin on top of the rafters first before positioning the glass instead of silicone. What do you think about that?
So when you did your roof on that log house, it was totally water sealed?
My rafters are about 10 feet long, so i was going to lay the 6 foot panels from the bottoms up, and then design a vented ridge system at the top out of polly. How would a glass panel work layed above the 6 foot glass panel up to the ridge to cover my top 4 feet? Is there some way you think I could get a sealed seam without overlapping these panels?
Old 02-13-2010, 10:56 PM   #4
jlhaslip's Avatar
laying the blue skin on the timber is a waste of the blue skin, in my opinion. Won't do anything.
yes, the roof was totally waterproof.
to use a piece of glass on the 4ft section above, I would consider rabbeting the bottom pane into the timbers and using the above method for the top sheet with a metal flashing under the top sheet/over the bottom sheet. Silicone the flashing to the top sheet so wind can't blow rain back up.
Old 02-14-2010, 11:16 AM   #5
Tom Struble's Avatar
Rewards Points: 2,002
very hard to seal these ''wet'' glazing systems,better off looking for a glazing bar system using gaskets and internal drainage systems
http://www.ussky.com/
Tom Struble is offline   Reply With Quote
Old 07-04-2015, 09:50 AM   #6
Rewards Points: 2
I really found your greenhouse post helpful . I would like to build a greenhouse this year constructed of old sliding door panes as well. If you found effective means of sealing the panes to the roof and walls, I would be greatful if you shared your sources and experiences. Any end result photos of your project would also be nice.
Bear Contractin is offline   Reply With Quote
Old 07-12-2015, 08:42 AM   #7
Rewards Points: 724
Over the glass or slider frame, I would use eternabond tape. Home made skylite with plexiglass, tape over perimeter flashing. The tape is now 10 yrs plus, no leak. Flashing attached with silicon before leaked.
carpdad is offline   Reply With Quote
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 12:56 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
liquid roof seal grendon Roofing/Siding 2 06-30-2008 08:15 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
