#1 |
Grace Roof Detail Membrane
Hi, Does anyone know of any online suppliers that carry Grace roof detail membrane? (9" and/or 18" widths)
My local l**wes and HD don't carry it anymore and I really need to get a roll of this in the next week. Any help would be greatly appreciated. thank you |
#2 |
Why can't you cut it down?
#3 |
I do not need a whole roll of the ice and water sheild. I am just using it around my chimney under the flashing when I replace it. The 9" roof detail membrame would be perfect for that and is about $75.00 less. I just can't find any in my local stores. Any help finding a store that carries this would be appreciated
#4 |
Pro Slate Roofer
Never heard of it. They have some for windows, but it's not for roofing.
I don't bother with it at penetrations. Correct install negates the need.
Frank To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#5 |
Doing This Way Too Long
Like tinner said, only reason you'd need it under your flashings is if you are not confident your flashings are installed properly. If you are relying on underlayment to waterproof a roof, you are doing it wrong.
#6 |
Residential Roofer
God Family Country Work Play
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
Super Moderator
Contact a local Roofing Contractor and see if you a\can buy a partial roll for you to cut down to sizes that you want instead of searching all over for the product all over tim-buk-too.
I know of the special sized pieces you speak of, but we always just cut special sizes out of full rolls. Also, try a siding or window installation company. These small width rolls are "Supposed" to be installed around the perimeter of window flashings. I believe even Tinner has a slide show demonstration on his website on the proper way to install them or how the proper way to install window flashings, which you could use as an informative view-point for your slightly different application, since the steps are the same. Ed
Stay Tuned For Our New Informative And Helpful Web Site, Coming Soon To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Flat roof questions, advice, ballpark estimate | JerryH | Roofing/Siding | 18 | 11-07-2008 05:08 PM |
| Modified bitumen vs 60 mil EPDM membrane Flat Roof | doingygirl | Roofing/Siding | 11 | 01-07-2008 09:41 AM |
| roof leak and EPDM membrane | dbai | Roofing/Siding | 8 | 10-28-2007 06:16 PM |
