GRACE Detail Membrane - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-23-2013, 04:17 PM   #1
GRACE detail membrane
I have a couple of valleys that need that need to be flashed where I tied my addition into an existing roof. What I was wondering is, if anyone has used the Grace detail membrane for flashing valleys? Can I just put the membrane down on the roof deck and thats it, and then weave the shingles over it? The product description according to them is that its a flexible flashing, just want to make sure I have it right.
NASCARFANGO88 is offline   Reply With Quote
Old 05-23-2013, 05:55 PM   #2
Rewards Points: 648
The detail membrane, as I understand it is more for areas where standard ice shield wont conform to the bends needed as easily.
For a normal valley, standard ice shield would work fine. Grace brand ice and water shield is great, though a bit of a pain to install compared to others due to the ripcord.
PatChap is offline   Reply With Quote
Old 05-23-2013, 09:10 PM   #3
roofingquotes's Avatar
For what I know you can just put it and that's it. Its also reroofable so you can just apply over an old underlay.
roofingquotes is offline   Reply With Quote
Old 05-23-2013, 09:27 PM   #4
Roofmaster
Rewards Points: 2,210
What do you mean? You put down a full sheet of ice dams protection material, then run your felt over the sheet minimum 6 inches, then you install your valley in the usual way. I like closed cut. Is this an uncured elastomer that can be formed like epdm formflash? You don't need that for a typical valley, as Pat Said.
Rot caused by bituthene, Grace Vycor, storm shield, etc above deck joists? CDragon Building & Construction 4 10-24-2012 11:33 AM
Leaks in membrane roof at posts and edge leakhelp Roofing/Siding 13 09-09-2012 07:22 PM
Torch on roof membrane on deck canada55 Roofing/Siding 36 03-03-2011 02:18 PM
Grace Roof Detail Membrane 20ampbreaker Roofing/Siding 6 06-23-2008 07:42 AM
roof leak and EPDM membrane dbai Roofing/Siding 8 10-28-2007 05:16 PM
