Gothic Arched Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-03-2010, 07:01 PM   #1
gothic arched rafters
i am thinking of building a home with a gothic arched roof, and I cannot find any information on how to build the laminated rafters. very litte info on the net on this. can anyone provide any help at all. I have done my share of woodworking and built my share of sheds, garages and homes. I have used regular rafters many times but would love to see about building my own arched rafters.
flyboys3 is offline   Reply With Quote
Old 01-03-2010, 08:57 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I helped build a Proa with very curved outriggers. We took straight 4x4 fir and re-sawed them all into 1/4 strips on my bandsaw. Made a mold with blocks on a frame with 3/4" plywood on top. Once we knew all the guiding blocks were in the right spots, we covered the area in saran wrap like plastic, then mixed west system epoxy, and glued it all back together.
I would have to find, scan, and e-mail pix of the process.
tinner666 is offline   Reply With Quote
Old 01-03-2010, 08:58 PM   #3
Pro Slate Roofer
tinner666's Avatar
Oh, they were 14' or 16' 4x4's.
Old 01-03-2010, 11:19 PM   #4
Registered User
Rewards Points: 4,936
http://books.google.com/books?id=Udw...afters&f=false
http://books.google.com/books?id=DLV...0barns&f=false
http://books.google.com/books?id=_ko...ilding&f=false
http://www.woodworkersworkshop.com/roofing_rafters.php
You may have seen these, I didn't spend too long searching.
Be safe, Gary
Old 01-04-2010, 06:02 AM   #5
Pro Slate Roofer
tinner666's Avatar
I only looked at the first link. That's how we did it.
Old 01-04-2010, 05:42 PM   #6
No I did not see some of them. that is what I am looking for. I looked for most of the day and found very little. What I would like also is a "how to" book or something simular for the arched roof construction. This just seems to have stood the test of time(barns).
Old 01-04-2010, 07:45 PM   #7
Pro Slate Roofer
tinner666's Avatar
You're going to have to know the distance from wall to wall, outside measurement, of course. ( For the bird's mouth cut) You'll then need to know the thickness of your ridgeboard, if you're using one. You'll need to divide it's thickness by .50.
Then, you need to know how much overhang you'll want. Then, try a scale drawing, then a full sized mockup to see how it really looks.
Insulating attic floor AND rafters? John FX General DIY Discussions 11 10-10-2008 11:50 PM
Lookout rafters Clutchcargo Building & Construction 10 08-13-2007 12:34 AM
