Good Size Wrinkles In New EPDM Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-06-2011, 02:42 PM   #1
Good size wrinkles in new EPDM roof?
I have just had a flat rolled roof striped and EPDM applied in Boston MA. The roofer finished the job just prior to Tropical Storm Irene arriving. The roof appears to be watertight.
There are number of good size wrinkles in the EPDM.
Is this acceptable? Am I going to have premature leaking problems due to this?
Thank you.
Mark2 is offline   Reply With Quote
Old 09-07-2011, 10:49 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
Leakproof should not be the only measurable aspect of a properly installed roof.
I would not be happy with that finished product if it were my roof but I do not know what his contract states.
Old 09-07-2011, 02:58 PM   #3
Rewards Points: 1,418
I think that this is not a problem.
Old 09-07-2011, 03:03 PM   #4
Rewards Points: 252
The wrinkles will cause problems eventually, but so would cutting them out and patching the roof.
shazapple is offline   Reply With Quote
Old 09-07-2011, 03:09 PM   #5
Thank you for your reply.
Do you have experience with this type of roof?
Does it remain flexible in the winter? Might the weight of ice and snow on it cause it to crack. Or, if I step on the wrinkles in winter while brushing snow off the roof will it crack at those wrinkles?
Thank you.
Old 09-07-2011, 08:13 PM   #6
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I think so too. Not sure since I never had a wrinkle problem. I do think that if you try sweeping snow off, cracked bones will be much more of an issue since wet EPDM can be awfully slick!
tinner666 is offline   Reply With Quote
EPDM roof install questions SoxFan44 Roofing/Siding 2 08-23-2011 08:00 AM
Installing a Gutter on an EPDM Roof Linda135 Roofing/Siding 27 05-23-2011 06:12 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
EPDM Roof Plans stubits Roofing/Siding 44 05-01-2010 12:06 AM
