Is This A Good Idea? Flashing With Roofer - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-14-2011, 10:52 PM   #16
RFN-4A-LVN
Roofmaster417's Avatar
So is the last set of pix the installation process as it was happening???
I am curious.,.,
Roofmaster417 is offline   Reply With Quote
Old 10-15-2011, 08:02 AM   #17
MJW
Looks like his bucket buddy RM.
No need for tar on those nails if it is installed properly.
MJW is offline   Reply With Quote
Old 10-16-2011, 10:52 PM   #18
Rewards Points: 956
I am curious.,.,
yea they are in fairly chronological order. i believe that ornage thing is part of the circular saw/ battery
federer is offline   Reply With Quote
Old 10-16-2011, 10:54 PM   #19
Rewards Points: 956
Originally Posted by handy man88 View Post
It's interesting to see that the roofer installed the vent directly on top of the existing shingles.
When I had my exhaust vent installed, they removed the shingles around the roof penetration, installed ice and water shield on top of the sheathing, put the vent on top, and then installed the new shingles.
I would recommend, if the roofer didn't already, to put two dabs of caulk over the nail heads also, even though there are dabs under the vent's flashing.
well he did take up the shingles first. i didn't post every pic of the process in this thread. i think he also put a new ice and water shield. if you look at the pic with the plain black piece i posted. hope this makes sense?
Old 10-16-2011, 10:55 PM   #20
Rewards Points: 956
so does anyone want to comment on my questions?
Old 10-17-2011, 06:15 AM   #21
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
It's fine and not going to leak. He's not much of a roofer though. In one pic, you can see he nailed the roof right in the sealer strip which voided the wind warranty.
He should go to roofing school.
tinner666 is offline   Reply With Quote
Old 10-17-2011, 07:13 AM   #22
RFN-4A-LVN
Federer.,.,I agree with Tinner but is that a plastic damper vent? I always remove shingles that have nail holes anywhere near the sides of the flashing part of the vent.But as long as the shingle is nailed to the flashing then it should not be an issue.IMO.,
Old 10-18-2011, 12:01 AM   #23
Rewards Points: 956
oh man. can you please point out which pic?
yes it is plastic. is that bad?
Old 10-18-2011, 05:34 AM   #24
Pro Slate Roofer
tinner666's Avatar
It's the first one in the sequence Federer. The nail is supposed to be 7/16" above the keyway (shingle slot).
Not only that, but it looks as if there is another nail 3" above the first misplaced nail. If he was supposed to be 6-nailing, the 2 nails would be 7/16" up and 1-2" to either side of the keyway. Not in the black, as the expression goes, like we see here.
In the case of any warranty issue, the first thing the manufacturerchecks is nail placement. They can deny all claims on improper installation.
Old 10-18-2011, 06:17 PM   #25
Rewards Points: 1,088
Plastic does not withstand the elements as well as metal. That's why metal costs more.
If you're going to go through the trouble (hint $$$$$) to get it installed professionally, why put in an inferior product?
handy man88 is offline   Reply With Quote
Old 10-18-2011, 10:00 PM   #26
Rewards Points: 956
oh great. well thats good to know.
Old 10-18-2011, 10:01 PM   #27
Rewards Points: 956
well its too late for that now. damnit!
Old 10-18-2011, 10:23 PM   #28
FWIW, you may want to check to see what kind of warranty comes with that exhaust.
I do think though, that over time, that it will dry and crack.....especially since it's black, which absorbs heat.
Old 10-18-2011, 10:39 PM   #29
Rewards Points: 956
you are right. this is not looking good
Old 10-18-2011, 10:44 PM   #30
I can't comment on the point someone else made about the incorrect location of the nail, but WRT the plastic material, you should be OK for several years. Overall, it just may not last as long as a metal one.
I assume your roof is somewhat low pitched on a single story house, which is why you felt comfortable going up on the roof to take pictures. Worse comes to worse, just go back up there after a few years armed with a caulk gun or a new vent.
Drylok, good idea or not? bk626 Building & Construction 2 06-29-2011 08:33 AM
Adhesive window flashing and 30# felt Numb Building & Construction 4 05-23-2011 11:04 PM
Is using Luan to overlay soffit a good idea? ConstantChange Roofing/Siding 17 10-19-2009 08:48 AM
Roof Hook w/ Folding Ladder. Good Idea / Bad Idea? jjohanson Roofing/Siding 2 10-17-2008 07:45 PM
Would this be a good deal for a roofer or is it a dumb thought Doug Crf Roofing/Siding 5 05-09-2006 10:44 PM
